Old 06-25-2014, 01:14 PM   #1
Jsfucttruck
What Borgeson U-Joint on 72 Blazer Column?
I am getting parts for a guy with a 72 Blazer and he just did a crossover steering setup and now he wants to ditch the factory Rag joint-steering shaft setup. It looks to be 3/4" 36 on the steering box but I don't have the truck to measure what's up on the column end. Does anyone know? It looks to be the same as the lower by a pic.
Any help is appreciated.
Jsfucttruck is offline   Reply With Quote
Old 06-25-2014, 01:15 PM   #2
Jsfucttruck
Re: What Borgeson U-Joint on 72 Blazer Column?
Borgeson didn't know.
Old 06-26-2014, 01:41 AM   #3
argonaut
argonaut's Avatar
Isn't the flange welded to the double D shaft of the column? I think they make a fitting for the double D.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 06-26-2014, 07:24 AM   #4
ryanroo
ryanroo's Avatar
Yeah, the flange is part of the shaft. i think they are replacing that though. hopefully with a collapsible DD. the box is a 3/4"x36spl. i don't think the end of the column is actually splined. it is clamped and the clamp bolt also locks into a notch. you may have to weld the joint on if they dont offer a clamp on style.
i have been planning this for mine, but i am not anywhere close so i havent sorted out the details.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 06-26-2014, 08:50 AM   #5
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
You could just do what I do and use a steering shaft from a 84 to 96 Jeep Cherokee, it's pretty much a bolt in and the Jeep shaft has a built in vibration dampener. You will have to collapse the shaft a little and on the column end you will have to grind a small notch to clear the different location of the pinch bolt. I pick them up for about 25 bucks fom the salvage yards, I have a 200 dollar Borgenson shaft that I used in my old 1 ton and believe me the Jeep shaft is just as good.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 06-26-2014, 08:51 AM   #6
BLAZERMAN
BLAZERMAN's Avatar
Sorry I can only post 1 pic at a time on this Ipad.
Old 06-26-2014, 08:52 AM   #7
BLAZERMAN
BLAZERMAN's Avatar
Last one
Old 03-18-2016, 03:02 PM   #8
JMD
JMD's Avatar
Anyone else using a Cherokee steering shaft? Any pictures of one installed on a c10/k10?
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296
JMD is offline   Reply With Quote
Old 03-18-2016, 05:59 PM   #9
franken
https://www.google.com/search?q=Cher...ng+shaft+chevy
Old 03-18-2016, 08:07 PM   #10
JMD
JMD's Avatar
Originally Posted by franken View Post
Looks like those are all for 73+... are there any write-ups or videos for 67 through 72?
