06-27-2014, 05:40 PM | #1 |
'65 Suburban build has started
First off I would like to say hello to all on the forum, this is my first post and first adventure in the 2wd classic truck world. Sooo...thanks in advance for all the info I have been finding on this board and any people are willing to hand out!
Now....I picked up my '65 Burb about a month ago as a project for me and my 2 daughters (6 and 3...got to learn sometime!) She is a C10 with a rebuilt 292 i6 4-speed on the floor. Plans: Clean up rust, straighten body, possible paint C-notch, porter strong arms, and accuride some type of modern seating |
06-27-2014, 05:46 PM | #2 |
Re: '65 Suburban build has started
...ok...so first thing was to do a little tear down to see what I had to play with. Interior was ripped out, then doors, hood....
...and of course I found some interesting things that I could use a little advice on. Both door sills (inboard of the door seal) are rusted through. I am replacing both rockers sets and am currious if I need to pick up full pack panels for these bad boys? Is it truely a 3 piece joint?...outter rocker/inner rocker/floor pan Second...the driver side door header and roof have some rust issues, the roof should be a simple patch job but I was wondering what options I have in terms of new metal for the header...or am I onto metal fab? ...more pics to come as I start going through this... |
06-27-2014, 06:45 PM | #3 |
Welcome to the board from a fellow 66 Burb owner, I've always liked that color on the 60-66 trucks/burbs, looking forward to progress pics. You're in good hands on this board for a wealth of info.
66 GMC Suburban Custom 66 Chevy K10 Suburban |
06-28-2014, 08:13 AM | #4 |
Just responded to your IM you sent me, and now I came here..
Looks like you've got some work ahead of you if you're doing a complete restoration. Am I correct in guessing the suburban was restored at one time in the past? Also--your roof issue is concerning on the driver's side--have you checked the front eyebrow area yet over top the windshield? You'll be fabricating that upper door frame area for certain. Also--check to see how bad the water damage is as you'll likely find the caulking around the perimeter roof seam is dried and cracked allowing that damage to start. Also--the rockers are basically a two-piece job. The inner rocker/floor piece and the outer rocker are separate and joined with spot welds. In order to get at that area you've posted pictures of you'll have to remove the outer rocker (good luck saving it...) and work out out from there. As I asked before regarding it possibly being restored previously--you need to really start checking to ensure there was no half-ass covering of rust. Check the area around the front cowl vent area on the firewall as my suburban which came from northern CA had bad rust there, along with the roof rust you are getting to enjoy. Good start to your project.
My '65 Suburban Resto build-- http://smg.photobucket.com/albums/v6...65%20Suburban/ And it's story of being 'saved' http://www.jalopyjournal.com/forum/s...d.php?t=631495 |
06-28-2014, 03:43 PM | #5 |
Thanks for the feedback and tips hemifalcon, the burb was "restored" about 10 years ago but he just fixed what was needed at the time. After that it sat under a tree for about 5-6 years with some use. The passenger side is solid and the rest of the roof looks good but I'm still hunting. Going to try to do the rust the correct way without taking the body off so it will be a challenge. Fenders come off next and then I'll start drilling the spot welds off for the rockers. I already have new metal for the outside so I guess I need to pick up the outer floor section.
07-07-2014, 06:23 PM | #6 |
07-07-2014, 06:30 PM | #7 |
now onto the rough stuff...started cutting about the door header and found a nice section of rust:
I know a bunch will have to be cut out, I think I am going to back and finish the floors and rockers so I dont build a laundry list that is too large too quick. A few questions though...I think I will need to remove all the glass, its all in pretty good shape...any tips on how to do this while maintaining the glass? Also, where do I find all the replacement rubber? I dont want to rip it out if I cant get it back in |
07-07-2014, 11:07 PM | #8 |
07-10-2014, 12:51 AM | #9 |
07-10-2014, 01:48 PM | #10 |
Good luck, you definitely have your work cut out for you. Good thing you have the helpers.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
07-19-2014, 10:11 PM | #11 |
Hollister, CA.
Oh ya ... you have some rust too !
If you need more, just let me know ....
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
07-21-2014, 02:08 AM | #12 |
Thanks John! Told you I had some but your rig made me feel a little better about my task!
Thanks for the hood! |
07-22-2014, 09:27 AM | #13 |
When I see Rigs like John and this one from my65 I am so happy with what I got two years ago. Minimal rust and that in places that was easy to fix.
08-11-2014, 03:41 PM | #14 |
C10 CLUB Y QUE!
subscribed
06-12-2017, 04:29 PM | #15 |
whats your plans for the original gas tank?
06-12-2017, 04:33 PM | #16 |
Current plan is to clean it up, paint it, and throw it back in. Id like to get it hot tanked first. Still up in the air if i want to go with a larger tank...I have a new rear cross memember to allow for a larger tank, just not sure if Im going to run one or not.
06-12-2017, 04:39 PM | #17 |
if you ever wanna go big and dump that one im a buyer.
06-12-2017, 04:55 PM | #18 |
06-12-2017, 04:11 PM | #19 |
Well...wow...didnt realize the last i added updates to this was 3 years ago!!! Well...a third kid will do that to you! So, actually started the burb back up last year and started making some progress again...
Got her loaded up to take to my buddies shop to pull the body... My oldest with her first run at air tools..she is a big fan! ...body off with the help of my buddy Al and Ellie... ...frame ready to roll back home to start work... ...home ready for more fun! |
06-12-2017, 04:24 PM | #20 |
Some frame work and another helper! Love these girls!
More power tools!...air turned down and nuts already cracked for safety but dont tell her that Ready for the Ridetech gear to go in the back...thanks to Travis at Pro Performance! Rear suspension and cross member all test fitted and moved outside for more cleaning and to clear up space in the garage... |
06-12-2017, 04:28 PM | #21 |
...finally up to date after a few months off to do house work....time to start striping the 292. Its been rebuilt already...bearings/seats/valves/etc...next step...lump ports, cam/springs, intake (current thought is a 490 edelbrock 4barrel with clifford intake), and headers (current thought is for Clifford shorties)...
More to come...more parts coming from Travis at ProPerformance and CPP to get a rolling chassis so we can strip it down and go to powder. |
07-28-2017, 10:41 AM | #22 |
Never Ending Projects
Just so you know, no one can see you pictures because Photobucket doesn't allow 3rd party hosting now. They want you to pay $400 per year. You can likely see them, because it's your account but no one else can. This started about 2 weeks ago.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
07-31-2017, 07:44 PM | #23 |
Updated my last pics post with pics and here is a couple more...cpp 2.5" drop spindles and big break kit and a test fit with my rollers. Just need to mock up the front sway bar and steering before I strip down for powder...now to find time.....
09-08-2017, 04:20 PM | #24 |
A little more progress...got the sway bar located and tacked onto the my lowers, waiting to get my Boyd tank test fit before I blow it all apart for powder...also started tearing the 292 down.
09-08-2017, 04:39 PM | #25 |
A little more...my new compressor/tank mount and rear skid plate. Currently getting laser jet out of 3/16" mild
