Old 06-28-2014, 05:17 PM   #1
71sixgun
fuel pump to carb
Hey guys I am looking for a new line, fuel pump to carb. I have a 250, I already checked LMC. What about brake lines? Could I bend one of those up? What about the brake line connections, do they work with GM fuel systems?
71sixgun is offline   Reply With Quote
Old 06-28-2014, 05:46 PM   #2
trac209
Re: fuel pump to carb
Any steel 5/16 line would work for a inline 6. I've seen it sold in most auto stores and don't see why it would be a problem.
trac209 is offline   Reply With Quote
Old 07-03-2014, 09:19 AM   #3
camrycurt
camrycurt's Avatar
71sixgun,
Have you tried this to confirm that the brake line connectors work with your fuel pump and carb?
I have a 250 and need to replace that fuel line but have been worried about breaking those connections and then not being able to find something to replace them. Hoping you or someone else can confirm that the brake lines work.
Thanks, and good luck!
Curt
1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear
camrycurt is offline   Reply With Quote
Old 07-03-2014, 09:48 AM   #4
geezer#99
geezer#99's Avatar
Those pre built brake lines work great for fuel, brake, or cooler lines. They make different lengths, different tube sizes and different size ends for them.
Old 07-04-2014, 07:04 AM   #5
Jb70c10
If it helps, the pre made 5/16 brake lines have 1/2-20 thread fittings on them....
Jb70c10 is offline   Reply With Quote
Old 07-04-2014, 09:51 AM   #6
70STOVEBOLT
70STOVEBOLT's Avatar
A 5/16 brake line should work fine if you have the original fitting at the carb.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 07-04-2014, 07:49 PM   #7
71sixgun
yup! 5/16 work fine!!
Old 07-06-2014, 02:17 PM   #8
camrycurt
camrycurt's Avatar
Cool, thanks 71sixgun and everyone else. I'll give it a shot.
Curt
