Old 06-29-2014, 03:02 AM   #1
LudwigTheMad
LudwigTheMad's Avatar
Question Temp sending unit
Does any one know if there is a difference in the info (ohm) between the 67-72 unit and the 90's unit. There is a physical difference (the 72 sending unit is bigger round). I as as my guage is pegged on cold, and only moves about an eighth of an inch (but it does move).
if there is a difference, does anyone know what it is, so I can add a resistor and make it work?
That's right, I'm back in the game again. No it's not pink.....
1972 Blue and White Suburban.
LudwigTheMad is offline   Reply With Quote
Old 06-29-2014, 07:26 AM   #2
dirtyjim
dirtyjim's Avatar
Re: Temp sending unit
they are different.
there are a couple ways I know to get around it.
I'm not aware of anyone who makes a sender in the correct ohm's with a 3/8npt to fit late model heads.
you can run the 67-72 sender in the intake or water neck, it will read slightly cooler but not enough to matter in my opinion.
you can turn a 67-72 sender down and rethread it to 3/8npt, you'll need a lathe to do this.
I just happen to have one in my garage.
you can also use adaptor fitting as a stop gap until you can get a sender turned down and rethreaded
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
Old 06-29-2014, 07:35 PM   #3
LudwigTheMad
Anyone know the ohm range of each?
I can adapt the electronics easier than the modifieng the unit.
