Old 07-03-2014, 07:47 PM   #1
81GMCSierra1500
81GMCSierra1500's Avatar
Tachometer install.
Hi all,
I've got almost all the way done on a tach install that should've taken about half an hour... I am curious how I go about putting the tach signal wire (green wire) into the "tach" port on the distributor... Also, how would I be able to reach the distributor without drilling a hole in my firewall? I wanted this to be easier than it is proving to be...
1981 Sierra Classic 1500, 305 4BBL, Ltd. Slip Rear End
81GMCSierra1500 is offline   Reply With Quote
Old 07-03-2014, 09:02 PM   #2
SkinnyG
SkinnyG's Avatar
Re: Tachometer install.
Find an existing rubber grommet going through the firewall, and sneak it in through there.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is online now   Reply With Quote
Old 07-03-2014, 10:14 PM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
Could run it into the wire harness.
I put an extra wire in mine for choke and tach.
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 07-03-2014, 11:07 PM   #4
81GMCSierra1500
I would, but there is no wire running out of the "tach" port in the dizzy cap. Therefor, I have no way of "splicing into" a harness to get a signal... Do I go and buy the plug head for it, and run the wire directly into that? This shouldn't have taken me more than an hour to set up...
Old 07-03-2014, 11:38 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
A stock hei tach spot takes a crimp/solder on connection.
I used a couple of stock wires from my 87 harness,fit right in empty spot.
And then add to that behind the fuse box.
John
Old 07-03-2014, 11:30 PM   #6
Keckdl
Keckdl's Avatar
I used a female spade connector to connect mine to the distributor.
Dan
83 Chevy K10 Scottsdale, ZZ4, TH700r4, 4.10, 33"
Keckdl is offline   Reply With Quote
