Old 07-03-2014, 09:00 PM   #1
JointTech
JointTech's Avatar
cab trim rivets
Can I just cut off and grind down the little tab thingys on the back of the cab under the window?
Is it a rivet thats going to fall out later or is it some kind of weld?
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 07-03-2014, 09:15 PM   #2
Livrat
Member #1049
Livrat's Avatar
Re: cab trim rivets
its a welded on stud, cut away
Livrat is offline   Reply With Quote
Old 07-03-2014, 09:19 PM   #3
budnikguy
budnikguy's Avatar
Re: cab trim rivets
it is two tone trim separating studs...so if you are going two tune...score the trim and use those!
budnikguy is offline   Reply With Quote
Old 07-03-2014, 10:38 PM   #4
JointTech
JointTech's Avatar
Re: cab trim rivets
I have the trim. Looks really nice. Not going to reuse it. Probably put it on the parts board at some point.
I ground those things down and they disappeared into the surrounding metal so looks like its good to go.
thanks
72 C20 Long Bed
Old 07-03-2014, 11:24 PM   #5
hugger6933
Re: cab trim rivets
A lot of people don't know this but there is a tip that goes into the end of the stud gun dent puller system that is made to reinstall those rivets along the places like that where the divider chrome goes and the windshield chrome retainers clips as well. Some people put the clips on with a screw, not to say that is incorrect but it is more holes in a body that is apt to corrosion anyway. The truck where I had some damage to the area I removed the rivet, repaired the damage, and then replaced the rivet before the part was put back on. Jim
hugger6933 is offline   Reply With Quote
