Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 07-05-2014, 10:17 PM   #1
amashal
amashal's Avatar
Help hooking up speakers
Every radio I've hooked up before has 2 wires per speaker. A color for each then same color and a stripe. I bought a blazer and it has 4 6x9's and 2 speakers in the door that all cut in and out at will. I looked at the wiring today and off the radio is this
1 red
1 red/white stripe
1 yellow
1 black
Those I know.
The speaker outputs however are only 4 solid colored wires. Green,purple, grey, white. How do I hook up the speakers to that? Do they share a common ground? I will eventually replace it all but I need to do a lot of other stuff to the blazer first.
Thanks in advance for any info.
amashal is offline   Reply With Quote
Old 07-05-2014, 10:36 PM   #2
69chevytrucker
69chevytrucker's Avatar
Re: Help hooking up speakers
what brand of radio
69chevytrucker is offline   Reply With Quote
Old 07-05-2014, 10:42 PM   #3
amashal
amashal's Avatar
Originally Posted by 69chevytrucker View Post
what brand of radio
I don't know. It's an old aftermarket AM/FM cassette player but I don't see a brand name anywhere on it.
Old 07-20-2014, 04:57 PM   #4
Andy4639
Old member
Andy4639's Avatar
Wink Re: Help hooking up speakers
I would say they share the common ground.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 07-20-2014, 08:33 PM   #5
_Ogre
_Ogre's Avatar
many older radios had common grounds where the neg was hooked same as body ground
possible red 12v+, black 12v- and left, right speaker, common ground
imo the head unit is junk, you will get better sound out a $69 pyle head unit
shop air compressor timer
Old 07-21-2014, 07:54 AM   #6
Andy4639
Old member
Andy4639's Avatar
I agree you can buy pretty good radio's now for under $100.00 and they will sound a lot better.
