Cargo lamp help..
My cargo lamp does not work.. I have the right bulb in and I'm getting power to the cargo lamp switch.. When switch is on off only one wire is hot and when I switch it to on both wires are hot.. When switch is on I stick my tester behind the bulb switch and it's a hit and miss sorta thing.. It will light up so time and sometimes it won't.. Could it be a ground somewhere by the bulb pig tail?
Will I ever finish my 1986 stepper.. |
Re: Cargo lamp help..
Possibly a bad socket for the lamp itself. I've never looked at the wiring diagram for a cargo lamp, but if it's anything like the dome lamp, it would be hot all the time and the ground is switched. If that's the case, look elsewhere. It could be a ground problem. If it's a conventional switch that switches the 12v side of the circuit, then you're on the right track. You have power on both sides of the switch when activated, so the switch works. If you're only intermittently getting 12v at the socket itself, then that sounds like your problem if you have a constant 12v at the wire/s going to it.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 ![]() |
Remove the bulb then check for power. One side will have power, other will be grounded through the switch.
Thanks guys for your help..
I had the same issue with mine it was a bad ground . Rather then trace that all the way back I just made a lead and grounded it by the light it self.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
Can u tell me where exactly did you put the lead at? I want to see if this will solve my problem..
The cargo light is back to back with the dome light. Pull the dome light base and ground the white lead from the cargo light to one of the dome light mounting screws.
Thing is I don't have a dome light.. I have a light under the glovebox and ashtray area.. Behind my bench seat is a white and a orange wire can I do anything with those wires?
#9 | |
Those are the dome light wires.
Thanks guys!! I got it to work.. I ended up soldering one end of a wire to the white wire at the base of the bulb socket and wraped the other end to the mounting bolt.. Now it works fine..
