![]() Join Date: Oct 2010
Steering gear box moves
Trying to figure out my dead space in my steering, found the gearbox is moving. I see the bolt that holds it to the frame moves. Is this considered a cracked frame or just worn bolt issue, if so , how can i fix it. I have a viedo of it. Look at about the 11 second mark and
you will see the bolt move. http://youtu.be/qTORTEORsKw
2017 Silverado LTZ 6.2 1984 Scottsdale K10 - 468 700r 4x4 lwb 1978 GMC Sierra Grande K15 350 Soond to be 406 th350 4x4 swb 1968 GMC 20 305 V6 good ole wood hauler. ![]() Good Fences make good neighbors |
Truck junkie
![]() Join Date: May 2006
Re: Steering gear box moves
The bolts are no doubt loose but you really need to take a close look for a cracked frame. 90% of the time when I see that happening and remove the gearbox the frame is broken or cracking.
bolts are tight as I can get them, they seem to have the hole worn or maybe the bolts need to be replaced. I checked the back side of the frame, if its broke its not visible.
I haven't heard or read that the bolts may ware out on the gear box, is this a possibility?
Truck junkie
When they start moving around they wobble the hole out and also mess up the threads so its not uncommon that they don't tighten up. I never just tighten up the bolts its not worth risking lives over. Trust me. Bite the bullet and take the bolts out. Swing the gearbox away enough to get a good look (tis means uncoupling the rag joint as well) and replace all the hardware holding the box to the frame. If the holes are very distorted you will need to address that or it will keep happening.
ok, yea I planned on pulling it out and taking a look. I have never pulled the gear box out before, will be intresting.
Second Chance Program
You should probaby get one of these repair kits from offroaddesign,
![]() http://offroaddesign.com/catalog/steeringkit.htm
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
#8 | |
#9 | |
What Hump?
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
Yes its a 4x4 and has slightly oversized tires but no wheeling or bagging.
Tags |
gear box, steering |
