Rear End Questions
I just bought a 72 Blazer 4x4 with a stock 350, a 4speed and the 3.73 rear. I have a rebuilt 2.73 rear that was going to go in my 71 C-10 with a 250 but with that 350 I am thinking the 2.73 will be way better on gas mileage, my questions are:
1. Will the 2.73 affect the torque? 2. I assume it will so the pick up at a light will be slower, noticeably? Not looking to race just keep up with traffic, get off road in the mountains and in snow (which is going to require highway driving) AND get decent gas mileage. 3. Anything I should be cautious of doing the swap? 4. Assume something will need to be done with speedometer? Appreciate any input/advice offered. |
![]() Join Date: Sep 2008
Re: Rear End Questions
1 you need a 2.73 front or your 4wd wont work.
2 with the 2.73 you may need to use 4lo when off roading to compensate 3 a 2wd rear wont fit in a 4wd because the perches are farther apart |
Do you have a 2:73 front as well? How tall of a tire are you running. That gear will definitely affect your off the line as well as pick up running around. Your clutch will probably bear the brunt of it. I can't imagine you'd get enough improved mileage to make up for the burnt clutches and new front end gear. These trucks just aren't mileage monsters, regardless of gear. I really like the 3:73 and have ran that gear in just about every 4wd I've had. As to the speedometer, there are gears available to calibrate. I generally do that after I put the tire size I'm going to run on the truck since that affects gearing as well.
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
Really appreciate the info, looks like the 3.73 is staying where she is! The seller says he is only getting about 10 mpg, any suggestions to bump it to 15 or maybe better? I'd even look at changing the 4 speed out if needed...
#5 | |
![]() Join Date: Jan 2001
It's mighty good of the seller to be honest about his fuel mileage. A lot of folks fudge the truth when it comes time to sell. |
#6 | |
