Old 07-14-2014, 01:24 PM   #1
jjdowney
A/C Bracket help
I've been searching for anything to help me figure out how to install the compressor I just bought. Here is a pic of everything I bought. Anyone have any idea how this bolts on? I have a 72 C-20 with a 350. It had factory a/c but the motor has been swapped at some point. The guy also gave me the attached condenser which is taller than the one that was in the truck, I think he pulled it from a '76 maybe?
Are these brackets for a different motor?
jjdowney is offline   Reply With Quote
Old 07-14-2014, 02:17 PM   #2
Bigdav160
Bigdav160's Avatar
Re: A/C Bracket help
Definitely later than '72. Long water pump design and the condenser lines exit the wrong side.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 07-14-2014, 02:25 PM   #3
jjdowney
well, once I figure out where these came from I might have a set of compressor brackets and a condenser available...
Old 07-15-2014, 12:59 AM   #4
Andy4639
Old member
Andy4639's Avatar
Question Re: A/C Bracket help
I think they are off a full size car of the same years. 70-80 models.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 07-15-2014, 08:43 AM   #5
brown7373
brown7373's Avatar
One of the limiting factors on the condenser size is the way the hood latch brackets, both at the top and the bottom, limit the height of the condenser. The condenser you have is much taller than will fit a 72 truck.
brown7373 is offline   Reply With Quote
Old 07-15-2014, 11:07 AM   #6
jjdowney
Thanks, this new condenser is definitely too big.
Old 07-15-2014, 06:52 PM   #7
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: A/C Bracket help
Here are the correct brackets for a small block Chevy truck AC. I sold this set a while back.
