Old 07-17-2014, 04:28 AM   #1
Andy4639
Old member
Andy4639's Avatar
Question Fan shroud
Anybody have a good source for a fan shroud to fit around my electric fans for the stock radiator? I may try and make one but if I can find one cheap I just buy it.
I saw a article in a jeep magazine on how to make one out of wood and fiberglass.
I was also wondering if a factory shourd would fit over the electric fans and help it some to force the air through the radiator fins better.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 07-17-2014, 02:00 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Fan shroud
Depending on the fan setup; if you have a single fan, you MAY be able to use the hardware-store method of using a vent fan hood trimmed flat.
In past projects, I made shroud covers or radiator covers from ABS before. Its cheap enough, easy to cut, and you can heat it with a heat gun and bend it into any shape. Its flexibility and lightweight work well in the engine bay (just be careful with direct heat against the plastic, some will soften)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-17-2014, 08:11 PM   #3
Andy4639
Old member
Andy4639's Avatar
Wink Re: Fan shroud
I was thinking more on the line of a metal box basicly with 2 fan openings for my truck fans. Are either making a box out of sheet metal and closing it into my fans.
