Old 07-17-2014, 08:26 PM   #1
jcd9730
jcd9730's Avatar
Brake warning lamp problem
Trying to get my brake warning light to work correctly. It has never been hooked up, and the PO for whatever reason removed the wiring. There is no wire to attach to the prop. valve, so I don't know where to run the wire from it. I don't think the ignition switch is wired correctly, but I'm not sure how to do it right.
I've been looking at wiring diagrams, but I don't understand where to wire on the switch. I was thinking I could run a new line from the prop. valve to the dash or ignition switch, but I'm not sure how. I'm thinking that the ignition switch is wired incorrectly.
Pics would be very helpful, if possible with the relevant wires pointed out.
Josh
72 C10, 350/2004r, Porter Steel Pacs, and 40+ years of leftovers from strange POs...
jcd9730 is offline   Reply With Quote
Old 07-17-2014, 08:27 PM   #2
jcd9730
jcd9730's Avatar
Re: Brake warning lamp problem
Also, the temp guage has never worked as well. There is a wire running to the sensor on the block, but it has never worked. Probably related.
Josh
Old 07-17-2014, 08:28 PM   #3
jcd9730
jcd9730's Avatar
Also, the warning light comes on if I turn the key to the far right, past the run position. But when I turn to run, nothing.
Josh
Old 07-17-2014, 09:22 PM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Brake warning lamp problem
The brake warning light only comes on for a second while cranking it to let you know the light is working. That's how it's suppose to work. It want come on unless there is a problem in the system other wise.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 07-18-2014, 12:55 AM   #5
jcd9730
jcd9730's Avatar
Figured it out, the wiring was all screwed up at the ignition switch
Josh
