Old 07-19-2014, 08:16 PM   #1
JGross
In the paint shop now!
Well guys it been a long time coming but Project 65 Daily Driver in finally in the paint shop. When I started this project back in 2010 I know it would take a while but honestly I thought, two years at the most, but the more I did to the truck the more I found I wanted to do, and this forum didn’t help. Because this was to be my daily driver I first decided to not worry too much about body work or paint so I just fix the rust and painted it in my garage and didn’t worry about the bugs in the paint or the wavy body panels. But then can the 5.3L Vortec swap and that turned out much better than I had ever hoped. The truck was defiantly a 20 footer or maybe even a 30 footer, when people would walk up to get a closer look , I found myself explaining way I hadn’t done a better job on the body. So last year I decide to bite the bullet and finish the job. So this is what I did;
First I blow it all apart again and started on the hood. First I welded up the seam around the front then I sandblasted everything down to bare metal sprayed it with a spray on body filler and started sanding.
Then came the front finders, same as the hood, weld up seam and sand.
The bed was next, this took the most time because I wanted to get all of the waves out. Instead of welding up the seam though I used seam sealer and you guessed it more sanding
It’s kind of hard to see in this photo but I also filled in the slots in the vent cowl
Finally I shaved off the vertical drip rail
Well it’s in the paint shop now and if all goes well I’ll have it back the middle of Aug. Sometimes I ask myself if this is really the end and I’m finally done. The answer --- Hell no!
In case you’re wondering what I started with here’s my first post.
http://67-72chevytrucks.com/vboard/s...d.php?t=405551
JGross is offline   Reply With Quote
Old 07-19-2014, 09:56 PM   #2
ls60apache
Re: In the paint shop now!
you are doing some nice work ,that hood looks awesome,how many hours do you have in the hood by its self.
ls60apache is offline   Reply With Quote
Old 07-20-2014, 12:18 AM   #3
shortbed70
shortbed70's Avatar
Man can't wait to see it done! What color you going? Looks like someone has a lot of sanding to do!!
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 07-20-2014, 08:32 AM   #4
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Looks great!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 09-07-2014, 02:29 PM   #5
JGross
It's Back
Got it back from the paint shop last week and it went together with out a problem!
My daughter put this together for me.
Old 09-07-2014, 03:21 PM   #6
Bigru
Bigru's Avatar
great job
1965 Short Fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=637478
1983 Short Fleet (Under construction for my 13 year old son)
2008 GMC Denali
2012 Harley Roadglide
Follow me on Instagram: Ru_django
Bigru is offline   Reply With Quote
Old 09-07-2014, 05:06 PM   #7
Greg63
Enjoy your truck
Greg63's Avatar
Looks fantastic.
Greg.
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 09-07-2014, 05:16 PM   #8
TJ's Chevy
TJ's Chevy's Avatar
Looks super good!
Old 09-07-2014, 05:41 PM   #9
oem4me
Nice work! From where do you get your fresh air now ...or do you?
Old 09-07-2014, 07:10 PM   #10
JGross
I have a VintageAir ac for temp control.
Old 09-07-2014, 07:22 PM   #11
RANDY COX
RANDY COX's Avatar
Nice!!!!!!!
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 09-07-2014, 11:04 PM   #12
Jeff La
Truck looks really nice
Jeff La is offline   Reply With Quote
Old 09-08-2014, 08:10 AM   #13
Clyde65
Clyde65's Avatar
You did a great job!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-08-2014, 08:21 AM   #14
1963c-10
1963c-10's Avatar
Great job on the body work. Truck looks great!!!!
1964 Short bed trailer
Old 09-08-2014, 10:06 AM   #15
wayno
Man she looks gorgeous - nice work
64 Step Side - The Mistress
wayno is offline   Reply With Quote
Old 09-08-2014, 10:44 AM   #16
JWheeler331
JWheeler331's Avatar
Man, that looks great.
Our 1965 Build
http://67-72chevytrucks.com/vboard/s...79#post6204879
JWheeler331 is offline   Reply With Quote
