Dual Exhaust Routing??
This is regarding a 4wd Blazer. I'm wondering best route to go regarding Dual Exhaust. What is the best muffler configuration to get the pipes to route properly. Center in - Offset out or Offset in - Center out or?? .Would also like to put an H pipe just behind the transfer case and keep the tailpipe outlets behind the tires similar to stock. I would like some insight and pictures would be awesome if you have them showing routing and hanging. I am leaning towards Spintech mufflers.
Thanks for any help.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
![]() Join Date: May 2007
Re: Dual Exhaust Routing??
Here is how I did mine.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
Thanks for the pictures. Ive seen the H-pipe mounted in that location but always bent under the Transfer case tailshaft. Never seen it over before. Looks very clean. Is there lots of clearance to the body when mounted? No body lift is there? Is that 2.5" pipe? Thanks for your help.
This is how mine was when I bought it. It doesn't have a crossover pipe. It looks like the inlet and outlet are both on the edge of the muffler, neither are centered. I'm not sure what brand of mufflers they are. Notice there is a bend to get the right side over the transfer case and they dump out the side just behind the rear wheels.
My toys: 1971 GMC Jimmy 2008 Hummer H3 Adventure 2003 HD Road King |
I put this together, 2.5" tube exiting out the sides in front of rear tires as my fuel tank is in the way.
1972 Blazer build: http://67-72chevytrucks.com/vboard/s...d.php?t=615744 |
Definitely getting some great ideas here. Really appreciate the pictures. Thanks.
![]() Join Date: Jun 2012
here is how i routed mine. i put the crossover in front of the transmission.
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
That is gorgeous.
Looks great. Do you have any other pictures of the H-pipe area once mounted?
Thank you!
This is the best pictures i could find of the H pipe. I can take some more if you like.
Mine is 2 1/2". I think the cross over is 2". With it going over the yoke, there is no clearance problem. Ideally the balance tube should be further ahead than mine is. I am running full length headers, so in my case, there just wasn't any good place to put it.
One of the First
![]() Join Date: Jan 2000
I routed mine out the back like this:
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
One thing to keep in mind when tucking the exhaust up so high is that the radiant heat will really warm the floor up a bunch and heat up the interior. You don't want the mufflers too close to the floor or the tub. I installed my cross-over under the transfercase rear output and put a mechanical union in it so I could remove each side of my exhaust system seperately if I need to, to perform maintenance or whatever. With a fully welded cross-over, the exhaust system is pretty much stuck in place unless you cut it out. Just my $0.02.
#14 | |
Here are a couple of shots of the crossover.
#15 | |
#16 | |
One of the First
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) Last edited by D.PASSMORE; 07-24-2014 at 02:09 PM. |
#17 | |
My cross over pipe is in the exact same location that the factory Y-pipe would be on a truck with a LS motor. I have never heard of any factory problems with the transmission getting hot due to the Y-pipe? Since my exhaust does not have cats or a restrictive stock muffler and it is way more "free flowing" than a stock system i don't think there will be a problem. From what i have read a crossover pipe on a stock ls engine does not add or take away from torque or power it just helps with the exhaust drone. So that is the reason i went with it.
#18 |
I like that exit look. Very clean.
