Old 07-21-2014, 09:10 PM   #1
ford37502
'56 Cab Wind Noise
Picked up a really sweet '56 pickup a couple of months ago for an incredible price. It was built with all the right stuff, but I have an incredible issue with wind noise around the doors. The cab has all new weatherstripping installed and the latches seem to be set right ... the back of the doors are flush to the cab openings. I took a dollar bill and closed it in the door in several places and it slid out with zero resistance, so the seals aren't touching. Have no idea the manufacturer of the seals but they appear to be good quality. Any thoughts for next steps to take?? I REALLY do not want to drive a vehicle with that kond of noise. Thanks for any suggestions
ford37502 is offline   Reply With Quote
Old 07-21-2014, 09:25 PM   #2
Highsider
Highsider's Avatar
Re: '56 Cab Wind Noise
So, I just had the door gap aligned as close to perfect as a 1957 truck could be. Add that I had new Steele brand (premium) door rubber installed.
I can see daylight at the point I marked as well as wind noise.
I just added some premium closed-cell foam on the upper/forward corner, just inside and parallel to the Steele rubber. It isn't noticeable and has reduced noise, somewhat. I will start over and use a longer piece and see if that helps.
Jimi J from I-Oh-Way
'57 Panel 3105
Met this deer...
Roof Swap on my Panel
Jim's Bread Truck
Highsider is offline   Reply With Quote
Old 07-21-2014, 09:45 PM   #3
Daze57
Daze57's Avatar
Not to sound like a jerk but is the rubber around the door faceing the right way ?
Daze57 is offline   Reply With Quote
Old 07-21-2014, 10:00 PM   #4
Highsider
Highsider's Avatar
Good point.
For mine anyway, yes, it is and I think it was the new recently self-installed Steele on the rear barn doors was found to be azz-backwards, when it went to the body shop.
'57 Panel 3105
Met this deer...
Jim's Bread Truck
Old 07-21-2014, 10:14 PM   #5
butchp
Put wd 40 on cab and black silcone to rubber and shut door. Try dollar bill again add silcone till there is drag. Door should be inside of wind line on front or door even or out in the back. Add silcone where needed and WD to body so it wont stick.
butchp is offline   Reply With Quote
Old 07-22-2014, 12:03 AM   #6
ford37502
Thanks Butch.... sounds like a good way to get where I need to be. Would you suggest that I work the front side first since that gets the most wind pressure?
I had considered installing a small profile/ Soffseal seal on the body side matching the door seal, but wasn't happy with seeing the seal on the body.
Old 07-21-2014, 11:59 PM   #7
ford37502
OK....good question, but I haven't a clue which would be the proper orientation of the seal. I've searched the web for pictures, but can't find anything. Could you either describe the right way to face the seal or attach a picture to a reply, please?
Old 07-22-2014, 03:41 AM   #8
Daze57
Daze57's Avatar
type in 'direction of door seal ' in the search box and you;ll find a 59 apache blog - it has door picts ; he has his on the wrong way - the ''shoulder '' or higher part of the seal should be facing the cab .
see if yours is like the pict - if it is you need to reverse it
hope this makes sense !
Old 07-22-2014, 08:29 AM   #9
ford37502
Daze57...just checked out the search you suggested and sure enough, the seals are in bass-ackwards, and I completely understand how it happened.... the seal is a perfect fit with the long side tucked nicely against the outer door lip !!!!!
Thanks for all the replies. I'll let you know how it turns out
Old 07-22-2014, 07:22 AM   #10
1project2many
OP: I'd expect noise to be from the upper forward corners. Those old cabs weren't built with the same quality as today's vehicles and you may end up setting the door more than factory spec'ed 1/8" inside the cab opening at the front to get the gasket tight. I've used the silicone trick but it's a last resort.
1project2many is offline   Reply With Quote
Old 07-22-2014, 08:33 AM   #11
solidaxel
solidaxel's Avatar
As a last resort, I have used a block of wood and a come-a -long (before glass installed) to force the door into its final position. We used several different doors to finish up our stretch 53...........................................Ben Franklin bills are much thicker, at least they feel that way, when I have them in my wallet!!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 07-22-2014, 01:07 PM   #12
_Ogre
_Ogre's Avatar
i installed the weather strip on my doors backwards when i first built it
just recently turned it around, i still have wind noise at 80mph but not near what i had before
now when i go thru the carwash the cab does not flood
if it looks right, it's probably wrong. this is the correct way to orientate the weather stripping
shop air compressor timer
Old 07-23-2014, 10:10 PM   #13
Highsider
Highsider's Avatar
Here is the Steele door seal, purchased in December.
Completely different design.
Cost was about three times the typical seals.
'57 Panel 3105
Met this deer...
Jim's Bread Truck
Old 07-24-2014, 08:35 AM   #14
ford37502
Hey Highsider... thanks for this picture..does this seal work??? I found the Steele site and they have 2 different seals, one larger in profile for "hard to seal" doors, but there were no pictures. I'm not so concerned about the appearance as I am about getting rid of the NOISE !!!!
Old 07-23-2014, 10:42 PM   #15
Daze57
Daze57's Avatar
hmmmmmmmm not too crazy about that seal
Old 07-24-2014, 11:23 PM   #16
Dan in Pasadena
Dan in Pasadena's Avatar
Why? You spend a lot of time with the door open examining it? Showing it off? Seems that if it works well, who cares what it looks like?
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 07-24-2014, 07:38 AM   #17
1project2many
Gaaa-ron-teeed to stop wind noise and water entry, eh?
Old 07-24-2014, 11:35 PM   #18
Daze57
Daze57's Avatar
if the seal works - thats what matters (to me)
and i guess i am too used to the original style of seal .
but if it works for whomever - so be it !!!!!
i dont spend time examining seals - all i care about is quality - and that it does what it is supposed too. other than that ..................well thats it !
no prob sir -
