Front buckets w/console in rear of 73-87 crewcab?
Probably been done....searched on here for pics or info for hours. Nothing.
So, my question is: Will factory front 73-87 buckets mount in the rear of a 73-87 crewcab? Anyone have pics of this done? Mounting or bracket tips? Suggestions? I'm swapping in a set from a suburban up front and I have a line on a 2nd set. They're an exact match with console. This HAS to have been done before...no? Thanks for any info or help! I could swear I ran across a pic of a crew with 4 blue cloth buckets and 2 consoles on here somewhere... |
C'mon...50 views and not a word? Gotta be someone who did or tried this?
Re: Front buckets w/console in rear of 73-87 crewcab?
I can't answer your question if its been done before but I don't see why it couldn't be done. Just buy the set and try it. Anything can be modified to fit.......usually.......
88' Chevy V30 3+3 4x4 Dually 454 TBI/NV4500/NP205 |
Getting Old; Going Broke
Only ones I've seen it in is those custom conversion trucks with the extended cabs done on them. The seats are not factory nor is the big console that goes front to back.
I'm sure what you're talking about has been done a few dozen times. Four doors, four seats. Perfect sense.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
I do not see why it wouldn't work. Back seats are the same as a standard cab truck. If they are Suburban seats, you'll have to modify the rear of the slides as many have done when putting them into a standard cab. As far as the console, I don't see a problem there either.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold ![]() 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
Thanks for the info....guess im fabbing!
I was expecting that...I was just curious to see if anyone had factory bracket swap tips to make this more of an exact(ish) fit! |
#7 | |
78K & 79C Jimmys
different floors etc tho,here are some conversion seats watch for thin seat tubes,on custom seats mine kept breaking
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Thanks for the info guys! I'm gonna put the four factory front burb buckets and pair of consoles I dug up in the 'ol '79 crewcab. I like the "should'a been built this way" look. Factory period correct parts that fit and look better than what was available seems like a no brainer.
![]() Join Date: Apr 2009
i would think factory bucket brackets from a regular cab would fit the rears in a crew due to the fuel tank hump.
1981 Chevy C30 440 Holmes 42K one owner miles |
