Old 08-06-2003, 07:58 PM   #1
1970blazin
Blazerless:-(
1970blazin's Avatar
Installing new tach gauge in a non-tach dash cluster?
I would like to insert a tach gauge into my existing dash cluster, Does anyone know what that involves? I have my dash out already and a limited amount of $$$. My dash cluster is in good shape and has a new bezel. Also can I change the mileage on my odometer? I just put in a new engine and would like it to reflect my new mileage. Is that legal?? Anyways- any advice will be appreciated alot!
1970blazin
1970 CST Blazer-Orig. Dark Blue-SOLD
Progress Pics of Blazer for sale
1970blazin is offline   Reply With Quote
Old 08-06-2003, 08:34 PM   #2
72BLAZERDUDE
72BLAZERDUDE's Avatar
You will have to get a new printed circuit. Th ones for a tach dash are designed to have something in the middle hole. Yhey will fit around an aftermarket tach. You will have to do alittle bit of cutting on the other parts of your dash assy. As far asresetting your odometer, If you are never planning on selling your truck it probably wont hurt. Alot of guys reset theirs when they put a new engine in. I imagine it is probably illegal in most states. You would probably have to check with your local MVD.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 08-06-2003, 08:37 PM   #3
JimKshortstep4x4
Smile
It is not hard to install into a dash gauge cluster. You will need (6)
things in order to change it out. Kits are available.
You will need the following items:
Tach
New face
Reveal
The sheet metal housing
Tach wiring
Tach printed circuit
You can use your existing bezel if it is for a gauge cluster.
Jim
Old 08-06-2003, 08:57 PM   #4
MOTHERTRUCKERS
We have the tach conversion kits for 229.00 in our catalog or can get you each piece seperate.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 08-06-2003, 10:14 PM   #5
miket
miket's Avatar
Are you looking to install an "oem" tach or an aftermarket tach?
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 08-06-2003, 11:33 PM   #6
DanoDMano
Pronounced "Pew-al-up"
DanoDMano's Avatar
I installed an aftermarket Tach in mine, without buying anything,
I just soldered in jumper wires for the printed circuit board, and used my Dremel to cut out the hole!!
Classic GM Trucks of Washington Club Member
1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's,
Power Locks,
Truck Photos
DanoDMano is offline   Reply With Quote
Old 08-06-2003, 11:41 PM   #7
GMCrazy
David Tye
hey Dano, could you post a pic of that? im thinking about doing the same thing
David
-68 GMC w/327
GMCrazy is offline   Reply With Quote
Old 08-07-2003, 12:51 AM   #8
DanoDMano
DanoDMano's Avatar
Yeah I'll try to take some photos tomorrow!!!
It was pretty easy to do, and I didnt want to
spend alot on the project. I bought the tach
on e-bay for $19.95.
Power Locks,
Truck Photos
Old 08-07-2003, 01:16 AM   #9
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
Hey dano, I didn't even have to make jumper wires for mine. I just cut the little hump out of the back plate with a cut out wheel and ran the tach wires through it. I butted the back of the tach up to the back plate. I do have about an 1/8 of an inch gap between the tach trim ring and the dash bezel.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 08-07-2003, 01:43 AM   #10
1970blazin
Blazerless:-(
1970blazin's Avatar
Miket- I'm not sure if I want an aftermarket or OEM. My blazer is going to be pretty stock, but some custom things in the interior- so it doesn't have to be OEM.
DanoDMano- I'd like to see pics too!
1970blazin
Old 08-07-2003, 11:21 AM   #11
miket
miket's Avatar
70Blazin,
Here is a pic of a "Sun" Tach that I picked up fairly cheap and installed in a day.
Old 08-07-2003, 01:53 PM   #12
GMCrazy
David Tye
wow, that turned out nice!
David
-68 GMC w/327
Old 08-07-2003, 02:38 PM   #13
71-longbed
Its Magically Delicious
71-longbed's Avatar
miket ....what model number is that sunpro tach??? .... looks really good ...i'd love to do the same .... feel free to pm me with instruction ...thanks
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 08-07-2003, 06:42 PM   #14
72c10step
WHYBYNU when old will do?
72c10step's Avatar
miket,
I'd also like some more info on that tach. Please post it here or send me a PM.
-72 Chevy C10 Stepside
-2002 Chevy Silverado 2500HD 4x4
-1984 Jeep CJ7
-1995 Polaris XCR600 Custom
-2003 Honda 300ex
72c10step is offline   Reply With Quote
Old 08-07-2003, 07:01 PM   #15
miket
miket's Avatar
Okay guys, it's a Sun Tach with Shift light ...I will get you the actual part number tomorrow...it is available from summit as a Summit branded product....it is also available from (those of you who live in the Pacific NW) GI Joes....thats where I got mine...stay tuned.
Old 08-08-2003, 12:56 AM   #16
miket
miket's Avatar
Here is a link to the Sunpro site and the specific model I bought....for those of you with White guage faces....they do offer a white tach.....don't pay the web price.....you can get these much cheaper elsewhere....
http://www.actron.com/cgi-bin/web_st...d=5372924_5431
It was easy to install....obviously remove the entire bezel from the truck and disassemble it...I cut the acrylic out with a dremel tool and cut off wheel...I also cut the metal housing behind it...wiring was simple...ignition/lights/ground and distributor feed. It fits flush in the bezel though I used a large hose clamp around the housing inside the bezel to secure it firmly (friction fit) in the bezel opening.
hope that helps...PM me if you have any questions.
Old 08-08-2003, 02:45 AM   #17
72gmcshorty
72gmcshorty's Avatar
Here's mine
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 08-08-2003, 01:01 PM   #18
DanoDMano
DanoDMano's Avatar
I am sorry I havent posted tach photos yet...
I am installing the A1 electric door locks and
havent been able to get my bezel off. I will do
it today and then post them when I get to work
at 3:00 PST.
Sorry...
Dan
Power Locks,
Truck Photos
Old 08-08-2003, 09:23 PM   #19
DanoDMano
DanoDMano's Avatar
Here is a couple pictures of my Tach, and Printed Circuit Board jumpered.
Power Locks,
Truck Photos
Old 08-08-2003, 09:26 PM   #20
DanoDMano
DanoDMano's Avatar
Another from the front.
Power Locks,
Truck Photos
Old 08-08-2003, 11:09 PM   #21
72c10step
72c10step's Avatar
DanoDMano,
That cluster looks pretty sweet! What brand and type of Tach is that? (Sorry if you already answered that, just point me to it if you have).
-1984 Jeep CJ7
-2003 Honda 300ex
Old 08-08-2003, 11:17 PM   #22
DanoDMano
DanoDMano's Avatar
Here is a link. I bought it on e-bay for $19.95.http://www.egauges.com/vdo_mult.asp?...t_Royale&Cart=
Power Locks,
Truck Photos
Old 08-08-2003, 11:30 PM   #23
72c10step
72c10step's Avatar
Sweet, looks like you got a great deal!
-1984 Jeep CJ7
-2003 Honda 300ex
Old 08-09-2003, 07:31 AM   #24
special70gmc
special70gmc's Avatar
another of mine
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 08-09-2003, 02:28 PM   #25
71-longbed
71-longbed's Avatar
miket..is that sunpro a 3 3/8 or 3 1/2 diameter??
thanks
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
