Old 07-24-2014, 06:33 PM   #1
Futom
3/4 ton rear diff options? Discs?
Hello all
I've searched the forum on this a couple of different ways. I was hoping some members could turn the light on hahahaha.
Doing research for my 86 3/4ton project and wondered, what is the best option for rear disc brakes on an 8 lug diff. My stock setup is the semifloating 9.5 with big drums and an open carrier with 3.73s.
Having been in the diff to change bearings and grease in the distant past I know the axle shaft splines are wearing out. Looks like lack of hardening treatment or something.
So I figure the whole setup can be replaced easily or I can part it together. A factory solution fits best, is most serviceable and cheapest in my experience.
My ideal setup would be 3.73 gears with a G80 posi and factory disc brakes with the drum in hat parking brake design rather than a Deville lever type. When I look online I see brackets for adding front discs to the rear with the caddy caliper. I'd rather not.
Was there a newer truck with a leaf sprung axle and discs that will bolt in? I'll go semi or full float. Or is the only decent option to go full floating and add dodge discs?
Thanks!
Futom is offline   Reply With Quote
Old 07-24-2014, 07:51 PM   #2
Futom
Re: 3/4 ton rear diff options? Discs?
This looks interesting.
t=618631&highlight=lug+discs03-05 8 lug disc
Maybe I can get an FF from an 85-91 sub and add these brakes
Old 07-24-2014, 08:56 PM   #3
v30crewcab
v30crewcab's Avatar
I am running an 02 silverado 2500 rearend in my truck. its a full float 14bolt with factory disk brakes. works beautiful.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 07-24-2014, 09:14 PM   #4
Futom
That towmissle is great! thanks for the note on the diff
