07-24-2014, 07:30 PM | #1 |
Cranking difficulty with advanced timing??
I just advanced my timing from 8*BTDC to about 16*BTDC to try and get some better performance and fuel economy.
Now, when I go to start it, even cold, it struggles to crank over, similar to a heat soaked starter. Should this be expected, or is something else going on coincidentally? This is on a bone stock '72 350 C-10 with points ignition. The throttle response is definitely better. Thanks.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor. |
07-24-2014, 07:44 PM | #2 |
Re: Cranking difficulty with advanced timing??
Yes, it is predictable that the engine is fighting itself at 16 degrees. You could even blow a hole in one of your pistons. Try backing off to 12. It might behave a lot better.
07-24-2014, 08:02 PM | #3 |
Ouch! That would be bad. I'll do that.
08-01-2014, 12:25 PM | #4 |
Finally got around to doing this (haven't driven in the mean time), and yeah, much better now...thanks.
08-01-2014, 07:02 PM | #5 | ||
"I ain't nobody, dork."
Bone stock engine and 16 degress is waaaayyyy too advanced. No "performance" to be gained. The neigborhood of 10 degrees will be fine... maybe even up to 12.
Gary
08-02-2014, 09:07 AM | #6 |
Your easiest upgrade for performance and economy would be a HEI dst. You will be amazed at the difference.
1968 SWB "Little White Truck" 1972 LWB LS 4l80 "Plain Jane!!" |
