Old 07-25-2014, 05:18 PM   #1
WhippinSaw
WhippinSaw's Avatar
powerglide kickdown linkage
Trying to get my passing gear linkage setup on my powerglide. Does the linkage fit into the upper hole so it travels the same way as the throttle Vavle linkage or does it go into the lower hole so it travel the opposite direction of the TV linkage?
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle.
WhippinSaw is offline   Reply With Quote
Old 07-25-2014, 06:31 PM   #2
Jurassic-1
Jurassic-1's Avatar
Re: powerglide kickdown linkage
If I a correct it goes in the lower hole . You can move it when it is unhooked and it will have a slight spring tension. This is the direction it should move under acceleration.
Jurassic-1 is offline   Reply With Quote
Old 07-26-2014, 01:26 PM   #3
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Try this pic for reference.
My KD cable is on the bottom.. There needs to be something that slips so it doesn't kick down till its wide open.
Here is another close up pic.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
