Old 07-26-2014, 11:18 PM   #1
bloody hammer
bloody hammer's Avatar
Rochester B
I recently rebuilt the Rochester B in my '62 Stepside (235) but it's still giving me trouble. At first it seemed to be "leaking" by fuel spilling over from the top. I assumed the float had dropped or some such so I rebuilt it with a kit from Mike's Carburetor (kit seemed good quality).
It runs great (better than before) but now it is leaking between the air horn and the bowl. From everything I've read I'm thinking one or both of the parts are warped. Some people have told me to double the gasket and see if that works. I'm also wondering if I can just put a little permatex or indian head stuff on the gasket and see if that makes a good seal.
Any advice or opinions?
bloody hammer is offline   Reply With Quote
Old 07-27-2014, 09:28 AM   #2
cortcomp
cortcomp's Avatar
Re: Rochester B
gas will eat that stuff up, you can try the double gasket, but yes, you probably have warped parts (likely just airhorn side, you can clean it up on a flat belt sander.)
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
Old 07-27-2014, 12:44 PM   #3
68Gold/white
Re: Rochester B
Might try to adjust the float down a hair.
What's condition of float? Brass?
68Gold/white is offline   Reply With Quote
Old 07-27-2014, 01:46 PM   #4
bloody hammer
Re: Rochester B
new float, in great shape and brass.
One thing I think I did wrong was when I measured the the float height I didn't have the gasket on there. Seems a small difference though and I'm wondering if it actually matters?
I found some permatex at the store that specifically says is "fuel resistant"... but not sure if I should use it.
Old 07-27-2014, 01:57 PM   #5
68Gold/white
Re: Rochester B
Do not use the permatex...it won't do what you want it to, and just make a mess.
Gasket sometimes need to be in place. I'd lower the level, see what happens. Even lowering it a little too much shouldn't hurt. Seen the instructions on those carb kits? A boat load of different settings for different engines w/ essentially same type of carb...
Old 07-27-2014, 02:06 PM   #6
bloody hammer
Re: Rochester B
Ok, cool. I'm gonna skip the permatex for now and will only try it as a last ditch effort before giving up and buying a new carb.
i'm going to readjust the float and see how it goes. if it still leaks I'll try the double gasket (there's an extra one in the kit, although it is slightly different).
I'm appreciating your help, by the way.
Old 07-27-2014, 03:19 PM   #7
68gmsee
Active Member
68gmsee's Avatar
Re: Rochester B
Agree on the permatex. Don't use any type of gasket sealer on carb gaskets.
There's only a few ways fuel can come out of the top -needle valve installed wrong or defective or float adjustment. There is one other rare possibility. Fuel pump putting out too much pressure and forcing fuel out.
In the past I have flattened out slightly warped carb surfaces by lightly sanding with sandpaper laid out on a completely flat surface.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 07-27-2014, 06:40 PM   #8
66Submarine
66Submarine's Avatar
Re: Rochester B
Doesn't seem to be rare at all anymore!
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 07-27-2014, 04:52 PM   #9
bloody hammer
Re: Rochester B
re-adjusted the float to 1-9/32" with the gasket ON this time. Still wet between the air horn and bowl but now i'm thinking the leak is actually coming from the fuel line connector.
Also, I'm now noticing that if I rev it real good it spits fuel out the vent (black circle in photo).
Old 07-27-2014, 07:57 PM   #10
68gmsee
Active Member
68gmsee's Avatar
Re: Rochester B
Originally Posted by bloody hammer View Post
....Also, I'm now noticing that if I rev it real good it spits fuel out the vent (black circle in photo)....
Fuel coming out of the butterfly shaft is a common problem. You can get bushings or kit to fix it. http://quadrajetparts.com/rochester-...aft-p-286.html
06 Trailblazer
Old 07-27-2014, 11:49 PM   #11
bloody hammer
Re: Rochester B
Cool, I will look into this as well.
I really want to get this carburetor back in shape rather than buy a reman but I guess that's not a bad backup plan.
Any suggestions on who to buy one from?
Old 07-28-2014, 09:23 AM   #12
68gmsee
Active Member
68gmsee's Avatar
Re: Rochester B
......Any suggestions on who to buy one from?
The kit is not cheap. Unless you have more than one carb that needs repairing I would take it to a carb shop. There's a few shops in Austin that do carb work. Ask them if they do throttle shaft bushing repairs.
06 Trailblazer
Old 07-28-2014, 10:58 AM   #13
bloody hammer
Re: Rochester B
Ok, I'll call around town.
But as far as buying one "remanufactured".... any recommendations? I saw one at a good price on rockauto.com and even tried to order it but the order got all screwy and they ticked me off when I called to sort it out so I just canceled the whole thing.
Old 07-27-2014, 06:37 PM   #14
66Submarine
Re: Rochester B
As mentioned, the carb might also be flooding from excessive fuel pressure; go ahead and check it. It should only be 3 to 4.5PSI.
Old 07-27-2014, 11:46 PM   #15
bloody hammer
Re: Rochester B
Ok, I see if I can pick up a tester. Can't imagine they cost too much and probably a good tool to have around.
Old 07-27-2014, 07:48 PM   #16
68Gold/white
Re: Rochester B
I have heard from a few about mechanical fuel pumps, having too much pressure. Problem might be that regardless of what brand, they are made in China.
I'd adjust it down another notch.
IF you get another carb, Keep your original. Factory rebuilt carbs usually have more problems, than solutions. It's hard to find an unmolested original anymore. Once you trade in the original, it's gone..........
Sometimes a needle/seat will bleed off, because of improper manufacturing. You can take a check ball slightly larger than the seat orifice, tap it into the seat, to make the seat is uniform. You have to make a judgement call on the size of the ball you have/or use, to make sure it will do the job
Old 07-30-2014, 09:39 PM   #17
bloody hammer
Re: Rochester B
I think I got it straightened out. I set the float lower and put a double gasket between the air horn and the bowl. It no longer leaks from the throttle shaft at the bottom or from between the air horn and bowl towards the top. I do not know WHICH of these things stopped the leaking... maybe both. Either way... there's no more leaking (for now).
Old 08-16-2014, 04:55 PM   #18
thelawdoc
Re: Rochester B
Bloody Hammer, how is your Roch B working out? I noticed that you got your rebuild kit from Mike's. I just ordered mine from him. He called me and gave me a lot of time on the phone as we ascertained the precise parts that my version of the B needs. He impressed me as knowing what he talks about. He advises against doubling the gasket because it puts something out of kilter -I don't recall his reason exactly. How did you remedy your leak at the throttle shaft? New Bushing? Or did you change the throttle shaft?
My Roch B seems to be an oddball. For one thing, it has stamping on it of "BC" which should mean that it has something other than manual choke. But all I have is manual choke. Then, whoever did the last rebuild of this carb put on a main gasket that did not have a hole where the carb has a hole. Also, the sintered bronze bearing was missing. Maybe all this is why I was getting bad mpg. We shall see. I have a stock 250. How is your mpg now?
-Alden
thelawdoc is offline   Reply With Quote
Old 08-17-2014, 02:01 PM   #19
bloody hammer
Re: Rochester B
-Alden
Alden,
The throttle shaft stopped leaking after I adjusted the float down some. I think the problem was simply too much fuel.
I still have some leaking between the air horn and bowl but with the double gasket it's more of a slow seeping than full-on leak. I know it's not a good long term solution but for now I'm leaving it be.
That's odd that yours is stamped "BC" yet has the manual choke. Maybe someone pieced it together from different carbs?
There's something odd about mine as well... it's stamped with a "C" but as far as I know there is no such thing as a Rochester C (upper left corner). Is that the same place yours is stamped "BC"?
Old 07-30-2014, 09:48 PM   #20
66Submarine
Re: Rochester B
Yep.
Old 07-30-2014, 09:50 PM   #21
bloody hammer
Re: Rochester B
Yep.
That seems like an awful lot of dirt to me for no more than maybe 15 minutes total time of idling... and with a brand new inline filter too.
Old 07-30-2014, 10:03 PM   #22
66Submarine
Re: Rochester B
That rust like that is fine enough to get past those cheap filters; it's an awful flour-like powder, isn't it?
FWIW, I had good luck cleaning the tank in my current DD out with a chain.
Old 07-30-2014, 10:45 PM   #23
bloody hammer
Re: Rochester B
It is awful stuff and I'm really regretting that I filled the tank up a couple days ago... hahaaa. I thought about draining it but I think I'll just run it close to out and then start all the cleaning.
I'll try the chain thing. I was reading somewhere that a lot guys use muriatic acid and then baking soda to neutralize.
LMC has new tanks for about $150 but I've heard people say they are made of really thin metal.... so, not sure about going that route.
Old 07-30-2014, 11:07 PM   #24
68gmsee
Active Member
68gmsee's Avatar
Re: Rochester B
I bought one from Spectra in Canada (GM49A) for my 68 about 6-7 yrs ago and was really pleased with it. Exact fit, like my original. They cost a little more but worth it if you're going that route.
If you decide to clean and/or replace drive it until you're almost empty and then get a cheap pump from Harbor Freight to completely empty it out. Buy a new rubber grommet and just use a razor blade to cut the old one out. It's also easier remove the front seat and pull it out passenger side.
06 Trailblazer
Old 07-31-2014, 03:16 AM   #25
gmcdeadhead
gmcdeadhead's Avatar
Re: Rochester B
i bought one from rock auto, i am pleased with it, i sent back a used 2-barrel as a core so i can keep my original b carb, they accepted it , rock auto is the cheapest around i found , thanks.
gmcdeadhead is offline   Reply With Quote
