cross member swap questions
Hey guys, started working on my 68 and one of the things Im doing is swapping the front suspension and doing a disc brake upgrade. I have donor parts from a low mileage 85 c10. I was wondering if there is anything special about swapping out the cross member. Will my mounts remain in the same place? And will it bolt in to the same holes or will I need to drill?
Thanks in advance.
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding ![]() My build : 68 C10 Short Bed Conversion |
Re: cross member swap questions
following =)
I guess nobody has the answer
Lots of people have done this successfully there is one bolt hole that has to be opened up but it will be very clear the one you need when you get there. Jim
Cool, thanks. Maybe we need a common upgrade sticky with links to all the threads with these upgrades.
here's what I'm going to use as a guide if I ever do it.
http://67-72chevytrucks.com/vboard/s...d.php?t=390446
1969 Chevy C10 2wd stepside longbox |
