Old 07-27-2014, 01:43 PM   #1
JIM1009
Shifter clearance problem with Muncie 4 spd and bench seat
Having clearance problem with Hurst shifter made for bench seat in my C10 truck. Shift handle hits the bottom seat rail for 2nd and 4th gear. The only solution I can see at this point to to move the seat back or raise it up. Was wondering if anyone else has had this problem and what they did to fix the problem. Thanks, Jim
JIM1009 is offline   Reply With Quote
Old 07-27-2014, 05:07 PM   #2
Greg63
Enjoy your truck
Greg63's Avatar
Re: Shifter clearance problem with Muncie 4 spd and bench seat
What shifter do you have?
I had an M21 in my '63 for 20+ years with a Hurst Competition Plus shifter and a pickup truck shifter bar.
I pivoted the mounting plate for the shifter on the tailstock of the transmission as far forward as I could and bolted the shifter body on. Once all the rods were adjusted and the shifter bar installed I had an inch or so of clearance between the bottom rail of my seat and the shifter in 2nd and 4th - but I had to always have the seat pushed all the way back (which is no big deal as I am 6' tall)
Greg.
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 07-27-2014, 05:13 PM   #3
66Submarine
66Submarine's Avatar
Yeah, my father's truck has the Comp. Plus with the '55-'57 car shifter lever, too. With me/him also being six feet tall I have never seen a need to move the seat forward from all the way back position. Is your seat all the way back or adjusted forward?
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 07-27-2014, 05:23 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
You might find relief by using this handle, with or without some fabricated adapter(s) to attach it directly to the shifter:
http://www.summitracing.com/parts/huu-5388620
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 07-27-2014, 05:25 PM   #5
66Submarine
Yep, that's the one I have. Supposed to be for a '55-'57 car IIRC.
Old 07-27-2014, 06:22 PM   #6
cortcomp
cortcomp's Avatar
if you look at that shifter and lay your standard hurst comp shifter over it, you'll see the shifter ball lands in the same place on both shifters, it only helps if the shaft of the shifter is hitting the seat, but for me, that'd have to be a tall shifter. I tweaked an offset shifter forward some for perfection, and made a shifter bracket to move the shifter up and forward, you can see it near the end of my build thread. It's an np440, but pretty close.
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
Old 07-28-2014, 09:03 PM   #7
JIM1009
I ended up moving the seat back about 3/4 inch and all is well now with seat adjusted all the way back. thanks guys JIM
