Old 07-27-2014, 11:16 PM   #1
68longhorn
68longhorn's Avatar
Tightening Power Steering Belt?
My p/s belt squeals on start and is a not tight enough. Whats the best way to move the pump? I loosened 2 bolts and a nut but dont have a solid place to pry against
1986 Custom Deluxe 10
1978 Caprice 2 door - sold
1937 Chevrolet 2 door sedan - project
68longhorn is offline   Reply With Quote
Old 07-27-2014, 11:28 PM   #2
MountainGoat1966
Re: Tightening Power Steering Belt?
Some GM models had a 1/2" square slot for a breaker bar to pull the pump tight, but we got left behind.
I think it's part of a conspiracy to make us damage our pumps and have to buy new ones.
I would suggest giving the belt a good spray of belt dressing and see if that helps.
Or, find a way to pry on the pump housing and not damage it.
"Off the grid and on the seven day weekend plan"
"One person cannot know everything, but between all of us, there isn't much we don't know."
MountainGoat1966 is offline   Reply With Quote
Old 07-27-2014, 11:47 PM   #3
Just call me Sean
Just call me Sean's Avatar
If you have a/c you need to loosen that first, then tighten the power steering, then tighten the a/c again.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 07-27-2014, 11:49 PM   #4
Nin92
Nin92's Avatar
I just use a pry bar between the water pump and power steering pump.
Nin92 is offline   Reply With Quote
Old 07-28-2014, 01:25 AM   #5
Just call me Sean
Oh yeah, how to pry. I use a wrench on the welded nut of the bracket. The one the bolt from the rear threads into.
Old 07-28-2014, 06:10 AM   #6
ron350
ron350's Avatar
You could use a v-belt tensioner.
http://www.fixitshop.com/thestore/prods/SUP-BJ10.html
Stock 75 C10 step side.
350 2 BBL, 350 trans. 150K miles.
ron350 is offline   Reply With Quote
Old 07-28-2014, 08:35 AM   #7
bnoon
I use the 90 degree end of my "Wonder Bar" pry bar against the frame and tuck it under the driver's side of the power steering bracket to lift it up into position.
I tried a pry bar between the water pump and the power steering pump, but the power steering pump metal feels so weak I just didn't feel comfortable prying against it.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 07-28-2014, 08:47 AM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
make sure you have this in place too,it can be tricky to keep tight if this bracket is missing
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 07-28-2014, 08:50 PM   #9
ron350
ron350's Avatar
Please forget that I mentioned using that V-belt tensioner it will not fit in between the pulleys.
The gap between the crankshaft pulley and the power steering pump pulley is only about 1-1/2 to 2-1/2 inches apart.
The last time I replaced the belt I think I used a 2x4 to pry between the frame rail and the lower edge of the power steering pump bracket.
Old 07-28-2014, 10:49 PM   #10
Oldriginal86
There was a tool I bought years ago when I worked at a GM dealer, it hooked under the the bracket and had a 3/8" square hole for a breaker bar. Just pulled up on the bar and tighten the adjustment bolt. If I can get a picture of it, I'll try to post.
Oldriginal86 is offline   Reply With Quote
Old 07-28-2014, 10:50 PM   #11
Oldriginal86
I just googled it and classic industries has something similar to the tool I have.
Old 07-28-2014, 11:01 PM   #12
MountainGoat1966
I remember that tool way back when and I was still wrenching for a living.
Almost bought one.
Old 07-29-2014, 02:01 PM   #13
ron350
ron350's Avatar
Is this the correct tool?
Thexton power steering pump tightener part # 383
Old 07-29-2014, 08:13 PM   #14
Oldriginal86
That's the same one on classic industries.
Old 08-01-2014, 12:03 PM   #15
68longhorn
68longhorn's Avatar
Thanks guys, i will get that tool. There is no great place for prying, i got it tighter just not perfect
Old 06-27-2021, 08:26 PM   #16
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Don't mean to bump though perhaps this is of value, at least on the 71-72 BBC pumps there are two thread holes, I believe these are exactly for tensioning the belt, eazy peazy & no damage.
IMO do not pry on the pump housing at all, I've done it before but this time I cared
Seen what happens to the top if you let your alternator go Ha!....It's why I bought a truck for my truck I guess donor was still good. Speak of alternators, I installed a 10SI with factory valve covers, wholly smokes tightened that can't be more than 1/4" off the valve cover. Surprised to see that, my 72 has an old alt, chrome covers and different upper bracket, the alt is off the valve cover by a mile on the same belt.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
