Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 07-28-2014, 12:09 AM   #1
Captainfab
60-66 Nut
6 Lug Rear Disc with 15" Wheels and an E-Brake
This set of brackets will allow you to have rear disc brakes on your 6 x 5.5 bolt pattern ’64-’87 GM truck 10 and 12 bolt rear differentials, and be able to run 15" wheels and also have an e-brake. This rear disc conversion is completely bolt on with one exception. The drum/wheel register will need machined down to approximately 3.06”. I do recommend upgrading to ½” wheel studs at this time, but it isn’t absolutely necessary for the installation.The rotors used with these brackets as well as the calipers are easily found at your local auto parts supplier. The basic application for the rotors is '88-'91 K1500 Silverado front rotors without F44 suspension. The calipers used on this conversion are the rear calipers used on the '79-'85 Eldorado, Riveria and Toronado as well as the 3rd gen F-bodies (I will get more specifics on those later). A complete parts list with part numbers is included with the brackets.
The cost on this set of brackets with installation hardware is $179.50. Satin black powder coating is an additional $28.00. Shipping within the USA is a flat $16.25. This pricing is always current and up to date. If you are outside of the USA, contact me for a shipping cost. For payments I accept PayPal and money orders. Credit card payments can be made thru PayPal. To place an order, post in this thread, send me a PM or send an email to captainfab454@hotmail.com, and I will give you the ordering and payment instructions and current lead time.
Old 07-28-2014, 12:14 AM   #2
Captainfab
60-66 Nut
Re: 6 Lug Rear Disc with 15" Wheels and an E-Brake
Here are some assembled pics. These 3 pics are with a typical '78+ metric front caliper.
Old 07-28-2014, 12:18 AM   #3
Captainfab
60-66 Nut
These pics are with the '79-'85 Eldorado, Riveria, Toronado rear caliper. This particular one is the wrong one for that side, but it was all I had at the moment to check for fitment
Old 11-09-2023, 02:10 PM   #4
burnie6bt
burnie6bt's Avatar
Captainfab, I purchased a rear disc kit a few year ago for my 1972 c10 using the AWD Astro Van front rotor and the D52 caliper.
I am looking at converting to a 6x5.5 rear axle. Would it be as simple as swaping my axles and using the later chevy truck rotors as mention in this kit? Or do I need to change the spacing, calipers, and rotors?
burnie6bt is offline   Reply With Quote
Old 11-09-2023, 04:42 PM   #5
Captainfab
60-66 Nut
Sorry but no it is not that simple. There is no such thing as a 6 lug rotor that has the exact same dimensions as the Astro/Safari rotor. Everything must be changed including the brackets. The only bracket that is the same are the base plates.
Old 07-28-2014, 10:29 AM   #6
TypeSL2
I want a set. Do I paypal you the $161.65?
James
TypeSL2 is offline   Reply With Quote
Old 07-28-2014, 11:03 PM   #7
Captainfab
60-66 Nut
Yes, PayPal works. I replied to your PM
James
Old 07-30-2014, 03:54 AM   #8
vortech71chevy
Nice! I'd love a set. My question is- would this rear disc setup pair well with stock 71-87 front discs? Or do I need to upgrade? Do I need to swap master cylinders or proportioning valves?
vortech71chevy is offline   Reply With Quote
Old 07-30-2014, 11:14 PM   #9
Captainfab
60-66 Nut
This rear disc conversion will work fine with a stock type '71-'87 front disc conversion, but you will have 5 lug on the front and 6 on the rear. Yes you need to change the master cylinder to a disc/disc master and the proportioning valve needs to be either a fixed disc/disc valve or an adjustable valve in the rear circuit.
Old 07-31-2014, 09:51 AM   #10
tonythezeek
tonythezeek's Avatar
i'm down for a pair, sign me up
tonythezeek is offline   Reply With Quote
Old 07-31-2014, 11:05 PM   #11
Captainfab
60-66 Nut
I will send you a PM with payment info.
Old 07-31-2014, 11:06 PM   #12
Captainfab
60-66 Nut
Here is a link to the correct calipers on Speedway.
http://www.speedwaymotors.com/Emerge...pers,1968.html
Keep in mind that you will need a left and a right.
Old 07-31-2014, 10:52 PM   #13
tjsblazer
tjsblazer's Avatar
Very nice. Do stock e brake cables work or how does the e brake set up work. Sorry for dumb questions. Thanks.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 07-31-2014, 10:59 PM   #14
Captainfab
60-66 Nut
I haven't installed any of these, so I do not have an exact answer to that question. I doubt that the stock drum brake cables will work, but I imagine it might be possible. Typically a custom length cable needs to be made, unless someone knows of an OEM application that works.
Old 07-31-2014, 10:56 PM   #15
tjsblazer
tjsblazer's Avatar
Sorry, 2 more. Does this alter the track of the rear wheels or the pitch between them and does the std 4" backspacing that are on 8 inch 6 lug rims like 15x8" steelies or ralleys fit.
Thanks again.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 07-31-2014, 11:02 PM   #16
Captainfab
60-66 Nut
Yes this disc brake conversion will increase your track width aprox 3/8-1/2". As long as you are using disc brake compatable wheels I do not see a problem. I have not checked fitment of any wheels yet. I can do that in the next couple days.
Thanks again.
Old 01-14-2015, 02:07 PM   #17
Campbel45
So these will work with the 15" steelie disc brake wheels (4 nub) or no? If so I am interested in a set
Campbel45 is offline   Reply With Quote
Old 01-15-2015, 12:27 AM   #18
Captainfab
60-66 Nut
I don't see a problem with fitment. PM sent
Old 08-03-2014, 02:55 PM   #19
TypeSL2
And how they look installed on the truck.
https://fbcdn-photos-b-a.akamaihd.ne...70190677_n.jpg
James
Old 08-03-2014, 02:56 PM   #20
TypeSL2
My bad, here you go.
James
Old 08-03-2014, 11:43 PM   #21
Captainfab
60-66 Nut
Thanks for posting an installed pic James
Here are a pair of new calipers on ebay.
http://www.ebay.com/itm/141016773439...#ht_4124wt_860
Old 10-09-2014, 11:27 PM   #22
Captainfab
60-66 Nut
ttt
Old 10-14-2014, 02:46 PM   #23
Dale_Brown
Capitanfab -- very interested in a set of these. Especially since Im within the first 6 to respond.
***The first 6 members to post here in this thread will pay only $150.00 for bare steel brackets plus shipping of $11.65***
How would you like payment? Also looking for a hydraulic clutch bracket for my 1970. Will the 60-62 with clutch work for me?
Dale Brown 443-354-2300
Dale_Brown is offline   Reply With Quote
Old 10-15-2014, 12:01 AM   #24
Captainfab
60-66 Nut
No the booster bracket hydraulic clutch for the '60-'62 will not work for a '67-'72. As I posted in your thread, I make a booster bracket with a hydraulic clutch conversion specifically for the '67-'72 trucks.
Old 12-01-2014, 09:06 PM   #25
tsm
I would love to get a set for my 1961 stepside. I Posting here to get the
" ***The first 6 members to post here in this thread will pay only $150.00 for bare steel brackets plus shipping of $11.65*** " deal
Still in effect correct? Do you have any custom e-brake cable kits you recommend?
tsm is offline   Reply With Quote
