Old 07-29-2014, 09:49 PM   #1
jd21476
jd21476's Avatar
Are my heater core lines routed correctly?
The shop that did my tranny swapped my heater core for free when it blew. Now I'm not getting any heat (not that I need it right now) because I think they routed my lines backwards. What do you think?
1973 Chevy K20
jd21476 is offline   Reply With Quote
Old 07-29-2014, 09:53 PM   #2
MountainGoat1966
Re: Are my heater core lines routed correctly?
In theory, it should work fine.
The heater core and engine both each have a 5/8" and 3/4" fitting, and the hoses really won't interchange due to the size difference.
The line going to the radiator could be moved to the water pump (it's a return line) and the fitting at the radiator securely plugged off.
I would check the air vents and vacuum lines to make sure the air gets to the heater core when it should.
"Off the grid and on the seven day weekend plan"
"One person cannot know everything, but between all of us, there isn't much we don't know."
MountainGoat1966 is offline   Reply With Quote
Old 07-30-2014, 04:38 AM   #3
donut
donut's Avatar
Check to see if it's getting warm to the heater core. You could have trapped air in it. If the HC is warm and coolant flowing ok, they may have forgotten to connect the blend door.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 07-30-2014, 08:34 AM   #4
bnoon
The coolant lines wouldn't matter one bit. Someone either broke or forgot to hook up the blend door vacuum line (or worse yet, it could have been broken inside the box when it was apart). Good luck! Oh, and go get a refund on that "free"!!!
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 07-30-2014, 05:54 PM   #5
cadillac_al
The advantage of the heater hose on the radiator is that, when the engine is cold you can take the radiator cap off and you can watch the heater core flow. If it's flowing then it should be getting hot.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
