Old 07-29-2014, 11:31 PM   #1
michael bustamante
michael bustamante's Avatar
250 power steering question
I found a 76 Nova today with a complete 250 in it with power steering. But it has emissions. Will the power steering setup work on the 67 to 72 Chevy trucks with a 250?
1967custom
michael bustamante is offline   Reply With Quote
Old 07-30-2014, 12:27 AM   #2
jabborabbo
jabborabbo's Avatar
Re: 250 power steering question
What is it emitting?
I'm sorry...I couldn't resist!
jabborabbo is offline   Reply With Quote
Old 07-30-2014, 07:27 AM   #3
MARKDTN
It depends on if it is a 1-piece head or seperate manifold. The brackets can cross over be made to work with some fabricating, but it is easier if you find a setup that matches your head configuration.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 07-30-2014, 08:09 AM   #4
NC67Chev
NC67Chev's Avatar
I think '75 is when the head changed, so I'm doubtful it will work if its the original set-up to that car.
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside
Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar
NC67Chev is offline   Reply With Quote
Old 07-30-2014, 11:49 AM   #5
68 IRON
68 IRON's Avatar
I think this is true ....But...on the newer Nova I got my setup off of was non integrated. And get EVERYYHING associated with the setup regardless if you think you need it or not...pulleys, brackets, even pieces of the hardware are special (top mount bolt for large PS bracket)
68 IRON is offline   Reply With Quote
Old 07-30-2014, 01:41 PM   #6
michael bustamante
A CRAPLOAD OF SMOKE! blown headgasket
1967custom
Old 07-30-2014, 01:43 PM   #7
michael bustamante
Iys the og 250. Ill look at the manifolds and head and see what it is and update
1967custom
Old 07-31-2014, 04:01 PM   #8
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
The seventy six will have an integrated head.The brackets are different but can be modded. A search should turn up how it needs to be modded. Get everything off the Nova if you decide to do it this way.Pulleys,pump,brackets,and hardware.I would get pulleys from water pump,alt,PS pump,crank(some bolt onto the Harmonic balancer). I've seen one done like this and it looked OK though you could tell it was modded to fit,function was good.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
