Old 08-01-2014, 07:09 PM   #1
Jake Wade
Jake Wade's Avatar
Exhaust manifolds
Does anyone know if there are problems using manifolds from a 67-72 truck on a 73-86?
Here is what I had in mind:
http://www.rockauto.com/catalog/more...213&cc=1410073
Curious about the exit or any interference issues
Jake Wade is offline   Reply With Quote
Old 08-05-2014, 07:25 PM   #2
Buzzman
Buzzman's Avatar
Re: Exhaust manifolds
I'm running ram horns on my 79 C10. Driver's side dumps straight down and passenger side angles back. Pretty tight around the stock starter, but I haven't had any heat-soak issues (yet). Painted them with POR 15 manifold paint and it's held up pretty well.
One other thing to consider is you will probably have to have new down-pipes fabricated for you by a good muffler shop.
79 C10 Cheyenne SWB Daily Driver
Buzzman is offline   Reply With Quote
Old 08-05-2014, 09:25 PM   #3
Ziegelsteinfaust
I got 2.5 inch ram horns from a corvette on my k20. A little tight but work great. I added band clamps to make exhaust removal easier. For service and such.
Ziegelsteinfaust is offline   Reply With Quote
Old 08-06-2014, 05:52 AM   #4
bob_o
bob_o's Avatar
I'm running these exact manifolds on my '75 GMC without issue.
bob_o is offline   Reply With Quote
Old 08-06-2014, 06:55 AM   #5
Jake Wade
Jake Wade's Avatar
Thanks fellas!
Old 08-06-2014, 03:09 PM   #6
parrisc19844x4_468
parrisc19844x4_468's Avatar
don't use those gasket though, get the ones that go over the bolts after you have the horns attached. This will save your some hair.
Also remember you will need longer center bolts(4 of them) as the horns are thicker in the middle.
2017 Silverado LTZ 6.2
1984 Scottsdale K10 - 468 700r 4x4 lwb
1978 GMC Sierra Grande K15 350 Soond to be 406 th350 4x4 swb
1968 GMC 20 305 V6 good ole wood hauler.
Good Fences make good neighbors
parrisc19844x4_468 is offline   Reply With Quote
Old 08-06-2014, 03:16 PM   #7
MountainGoat1966
Also, put some anti-seize compound on the bolts when you install them.
Will make it MUCH easier someday in the future if they need to come off.
"Off the grid and on the seven day weekend plan"
"One person cannot know everything, but between all of us, there isn't much we don't know."
MountainGoat1966 is offline   Reply With Quote
