66 License Plate Light Wiring
Does anyone know where I can get a replacement light housing/wire for the license plate bracket? I have seen (and accidentally purchased) one for a 61. I have also found the entire bracket with light/ wire included, but I can't find just the wire and bulb holder. Ideas?
Thanks! Michael |
Re: 66 License Plate Light Wiring
#3 | ||
1966 C10 Short Fleetside 1988 Sportster, 2008 Street Glide Ken's 1966 C10 build "Red Ale" Follow on Instgram: @cv_performance https://instagram.com/cv_performance Harley Performance Parts: CV Performance (Harley related) Enjoying the ride! |
I went to the parts store and bought a prewired pigtail 12 volt bulb (kinda like what you see in aftermarket guages) then I gutted the old socket from my lens assembly, made a rubber gasket for the base of it, and sealed up the hole in the gasket where I pushed the wires thru it. I then just replaced the lens assembly on the bracket with my home made gasket sandwiched between and wired it up to hot and ground. I also drilled a drainage hole in the bracket for good measure
That's the forum itself... it's having that issue all over, in different areas.
All I can do is edit the actual links... scroll down to visit the 60-66 FAQ Index. If you'd care to, please let the folks who run this joint know about the issue in the Site Feedback & Announcements area. -W Last edited by Woogeroo; 08-05-2014 at 08:20 AM. |
Thanks guys!!! Appreciate it...
