Old 08-05-2014, 09:01 PM   #1
oldman3
oldman3's Avatar
5.3 LS swap in a (look)
Hey Guys, this is about an LS engine swap, but it's in a 49 Dodge pickup. Yes I know this is the chevy truck site, but I've learned alot from all of you on this LS swap forum, and just wanted to post this on here. The Moderators may move this to Alternate Tinkerings, but I wanted to try the LS forum first.
Anyhow my son Mark has done 99% of the work, with me just helping when he needed it, and giving him info from this site on parts, etc. He started with a stock 49 Dodge pickup with flat head six and three speed trans. I beam front end and stock rear axle. This was a learning build from the start. Only going to show about 8 or 9 pics. If anyone has questions I will try to answer after I check with my son to make sure I'm right.
oldman3 is offline   Reply With Quote
Old 08-05-2014, 09:06 PM   #2
oldman3
oldman3's Avatar
Re: 5.3 LS swap in a (look)
Pic 1 Day it arrived at the shop.
Pic 2 Getting the front sheet metal off. This came in for installing a new front end, but when we found out how far back the front axle sits in the frame, and the front sump oil pan, things starting changing.
Old 08-05-2014, 09:11 PM   #3
oldman3
oldman3's Avatar
Pic 3 Installation of Mustang II style front end, with coil-overs and 5 on 4-1/2 bolt pattern, cause owner wanted to use the same 16" wheels.
Pic 4 After mock up of engine the firewall was moved back about 1-1/2" or 2" for clearance up front for radiator, etc.
Old 08-05-2014, 09:18 PM   #4
oldman3
oldman3's Avatar
Pic 5 Installed a 9" F--d rear axle with tri-angled four bar and coil-over shocks. Had axles and drums redrilled for 5 on 4-1/2 bolt pattern, same as front.
Pic 6 LS truck engine installed. We had to make up our own mount on the block, but used parts from Speedway going to frame. Headers also from Speedway. This is a drive by cable 2002 5.3 with a 4l60E.
Old 08-05-2014, 09:25 PM   #5
oldman3
oldman3's Avatar
Pic 7 Son fabricated the entire exhaust using a Camaro muffler with dual in and dual out with cross over set-up, it all 2-1/2".
Pic 8 This is how the truck sits with new suspsension prior to driving. Owner didn't want it low, still wanted it to look original.
Old 08-05-2014, 09:28 PM   #6
oldman3
oldman3's Avatar
Pic 9 This was taken yesterday, after we had it running and checked out ok, we set the front sheet metal back on.
Old 08-05-2014, 11:01 PM   #7
InitialBoss
Not a bad little sleeper!
1978 C-10 Custom Deluxe | I6 250 | SWB | Stepside
InitialBoss is offline   Reply With Quote
Old 08-06-2014, 12:54 AM   #8
Daaaanz67
Funny thing I contemplated a late 60 early 70s dodge ls swap today as I can remember riding in a dodge truck with my dad In my younger days.
Daaaanz67 is offline   Reply With Quote
Old 08-06-2014, 11:20 PM   #9
Root2812
Root2812's Avatar
Originally Posted by oldman3 View Post
found out all the injectors were plugged. Soaked them overnight and then cleaned them out, re-installed and it fired right up.
What did you soak them in and how did you clean them?
I am wanting to buy a 70 Roadrunner to build a superbird clone (can't afford the real deal) and I love the LS so much I contemplated putting one in there.
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 08-07-2014, 07:37 PM   #10
oldman3
oldman3's Avatar
Bought it at NAPA - Mac's 6402 Carb Cleaner with dipping basket. It's a 1 gallon can. Put them in basket and set overnight. Cleaned with a cotton swab, and blew with air. Then hooked up a spare injector connector, one wire to - side and one to + side of 9 volt battery. When you hear it "click" it's working again. only hold wire on the battery for a second...Jim
Old 08-12-2014, 07:20 PM   #11
Advanced Design
Advanced Design's Avatar
Jim,
Thank you for sharing the swap! Nice, clean, well executed and imagine the owner was pretty thrilled too.
Great looking shop there. Is that yours?
Advanced Design is offline   Reply With Quote
Old 08-12-2014, 08:25 PM   #12
cableguy0
Sweet build. As far as Im concerned this post belongs here just as much in alternate tinkerings. It can stay here especially since its definitely Ls swap related and you will likely end up helping others with info you post.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 08-12-2014, 11:22 PM   #13
oldman3
oldman3's Avatar
Originally Posted by Advanced Design View Post
Jim,
Thanks AD. Owner is picking up the truck tomorrow, he has already driven it, and was very happy. Yes the shop is mine, it's a 30X40 building (never big enough)...Jim
Old 08-06-2014, 01:18 AM   #14
ivorton74
ivorton74's Avatar
Sweet...i like it alot...its a unique piece
1983 C10 Silverado 5.3 swap
1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122
2001 BMW 530i 5 speed
2019 Nissan Titan SV Midnight
1979 Datsun 210 4 door
1980 Datsun 120y(back home in Trinidad)
ivorton74 is offline   Reply With Quote
Old 08-06-2014, 09:28 AM   #15
oldman3
oldman3's Avatar
Originally Posted by dec010974 View Post
I like it. It just show how flexible we are when it comes to LSx. Good work. Thanks for sharing.
Thanks guys for checking it out, and the compliments....Jim
Old 08-06-2014, 10:07 AM   #16
Low Elco
Neat! Nice work, guys! Hey, at Carquest they sell a thing where you pull the fuel pump fuse, screw a fitting onto the Schrader valve, and screw a can of high pressure injector cleaner on and let the motor run till the can runs out. About $60, as I recall. It may help.
Great little truck!
Low Elco is offline   Reply With Quote
Old 08-06-2014, 12:11 PM   #17
Daaaanz67
Also you can add seafoam to your fuel tank and go drive it. Worked great in my kids dirt bike after sitting for years.
Old 08-06-2014, 01:17 PM   #18
jamesjones
Freakin Awesome!
jamesjones's Avatar
Awesome. Love those old Dodges.
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee
jamesjones is offline   Reply With Quote
Old 08-06-2014, 01:34 PM   #19
oldman3
oldman3's Avatar
Great little truck!
Thanks everyone. I've used seafoam in my vehicles before with good results, as soon as we add more gas to tank we will add seafoam....Jim
