Old 08-06-2014, 09:51 PM   #1
Sklptrljay
Sklptrljay's Avatar
Weird clicking noise!???
I have a loud clicking noise that comes only when the truck is under a load/hard acceleration. I can rev it all day long and no noise. I did a brake stand without breaking the wheels loose and no noise. Only when i'm moving and under a load.
My neighbor said he had a u-joint that made a noise like that once. He might be on to something as I did change the carrier bearing a while back. Any thoughts or past experience with this before I dive in?
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 08-07-2014, 02:19 PM   #2
Sklptrljay
Sklptrljay's Avatar
Re: Weird clicking noise!???
Bump
Old 08-07-2014, 02:44 PM   #3
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Sounds like a U joint to me
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 08-07-2014, 03:25 PM   #4
captain69
Can you feel it in the drive train or steering wheel feet ect.. I have had wheel bearings do that,Rear ends, trans ect.. sounds like carrier or u joint probably just wiggle the drive shaft to see usually the thump when you first hit the gas
captain69 is offline   Reply With Quote
Old 08-07-2014, 04:05 PM   #5
Sklptrljay
Sklptrljay's Avatar
No, I don't really feel any vibrations. It sounds like a tapping or clicking noise, only under load and fades after I get off the gas. It lasts as long as it takes until I reach a cruising speed and am not getting on the gas.
It's pretty loud, enough that I'm consciously trying go easy on the gas pedal so I don't get funny looks from cars next to me. Speed doesn't make a difference, only how much strain is on the drivetrain.
Old 08-07-2014, 04:29 PM   #6
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Sounds like a u joint to me
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 08-07-2014, 05:22 PM   #7
Sklptrljay
Sklptrljay's Avatar
Hey, Dale! You would be amazed at how little I've accomplished on my truck since the get together last year .
Are you planning on another one this year?
Old 08-07-2014, 05:39 PM   #8
captain69
I dont know your setup as far as drive shaft. Solid or two piece. Check the u joints you can usually tell if there bad if you get under there and move it. Chalk the tires put it in neutral jack the rear up and spin the shaft see if it makes a noise and see if there is any movement in the joint.
Old 08-07-2014, 07:16 PM   #9
Ol Blue K20
I haven't accomplished a lot on Blue either but I did buy a rolling frame and a parts truck recently. So I guess my excuses are running out. I haven't thought about it due to so few in attendance last time. I am going to the one at Rene's in October. That one is great.
Dale
Old 08-07-2014, 07:29 PM   #10
Sklptrljay
Sklptrljay's Avatar
I don't know your setup as far as drive shaft. Solid or two piece. Check the u joints you can usually tell if there bad if you get under there and move it. Chalk the tires put it in neutral jack the rear up and spin the shaft see if it makes a noise and see if there is any movement in the joint.
I removed the driveshaft already and I don't see anything that looks out of the ordinary. I didn't think to check for play while it was in. I will throw it back in if I don't see anything wrong to the naked eye.
It may be your speedometer cable.
Negatory-I already checked that.
Old 08-07-2014, 07:32 PM   #11
Sklptrljay
Sklptrljay's Avatar
I am going to try to make that one also. If I can get this issue corrected I'll be pretty close to "finished"-.
Old 08-07-2014, 05:42 PM   #12
captain69
In my experience u joints clunk and vibrate when bad make noise when decel or sudden exel not while under load. But id start at the u joint and we can go from there.
Old 08-07-2014, 06:42 PM   #13
gipper
I may be your speedometer cable.
gipper is offline   Reply With Quote
Old 08-07-2014, 07:46 PM   #14
71K20chevy
71K20chevy's Avatar
Are you sure the engine isn't detonating?
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 08-07-2014, 08:09 PM   #15
Sklptrljay
Sklptrljay's Avatar
Man, at this point I'm not sure of anything! I really don't think it is a engine problem as it's fairly dialed in. But stranger things have been known to happen.
Old 08-07-2014, 08:15 PM   #16
71K20chevy
71K20chevy's Avatar
You are correct on the last part, definitely. As a matter of fact, I pulled my u joints out today, the one cup only had about 5 needles in it and was completely dry. But it never gave me any problems.
The problem is always what you don't think it is!
71 K20
64 GMC mud truck
Old 08-07-2014, 09:33 PM   #17
captain69
Brakes ok? Not hanging up on you.... or check the rearend fluid see if theres any metal would be next for me if the shaft looks good and its fine in neutral. Manual or auto?
Old 08-08-2014, 07:35 AM   #18
Sklptrljay
Sklptrljay's Avatar
Buddy/mechanic visually checked u-joints with me. All move freely and don't show any outwardly bad signs. The cap on the one that goes into the rear end was very slightly off center. We put it in a press and centered it. I'll put it back in and cross my fingers that it's just that.
Starting 7 days of 12 hour shifts today, so it who knows when I'll have a minute to do it. I'll post the results.
Old 08-08-2014, 08:25 AM   #19
slomotion
Old Duffer
slomotion's Avatar
Is it possible that you have a broken motor mount and under load your engine torques over causing the fan to hit something?
'68 Short C20 Flatbed Dually
w/ 292 4bbl, Langdon cast headers,
and WC T5 trans.
'81 G10 Shorty Van
"Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers
"Under promise, then over achieve."
slomotion is offline   Reply With Quote
Old 08-08-2014, 10:08 AM   #20
Sklptrljay
Sklptrljay's Avatar
I thought about that so I removed the fan and it still made the noise.
Old 08-08-2014, 10:00 AM   #21
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Exhaust leak? Crazier things have happened...
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 08-08-2014, 10:10 AM   #22
Sklptrljay
Sklptrljay's Avatar
Gary
That was my first thought. I pulled the old gaskets out and there was a small leak. I put in some malleable aluminum gaskets and it still made the noise.
Old 08-08-2014, 10:55 AM   #23
hamjet
hamjet's Avatar
""I have a loud clicking noise that comes only when the truck is under a load/hard acceleration. I can rev it all day long and no noise. _I did a brake stand 'without' breaking the wheels loose and no noise._ Only when i'm moving and under a load."" This would tell me it has to be from the trans tail shaft to the rear end, because the only time it makes the noise is when the drive shaft and rear end are turning... it does sound like joints....
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 08-08-2014, 02:26 PM   #24
chipflyer
chipflyer's Avatar
Believe it or not I had a wheel weight that was loose on mine, it wouldn't fall off but it would move far enough t to hit the beauty ring on the wheel under load. Took awhile to find it but it was the same kind of noise.
If you have clamp on weights you might check them.
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 08-12-2014, 03:03 PM   #25
Sklptrljay
Sklptrljay's Avatar
VICTORY!!!!
It turned out that one of the u-joints caps was just off centered enough to make that noise when I romped on it. Putting it in the press must have snugged it up a little and eliminated the movement.
Just a little fine tuning on the engine and I'm calling it good for now. I'll drive it all summer (what's left of it) and have my winter projects waiting.
