08-08-2003, 12:34 AM | #1 |
Adding power steering ?
I just bought a 69 3/4 4x4 that does not have ps. I want to add it and wanted to make sure this is a bolt up job. Do I just bolt on a power steering pump, change out the manual steering box for a power steering box and I am done? Any help and advice would be much appreciated. Especially where to pick up a good ps box and pump, can I use them out of the 73 and newer trucks?
1967 Suburban, my kids call it the SuburBEAN cuz its long and green. |
08-08-2003, 02:30 AM | #2 |
go bucks!
yup, ......might wanna pick up the hoses though!!lol! pretty easy mod. just make sure you have the pulley to drive the pump...and they're in line correctly.
'68 swb 1/2t 350/350th '86 lngbd 3/4 TON parts getter '49 gmc 1/2 t 5 window 350/350th '96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know? |
08-08-2003, 02:47 AM | #3 |
Ive done the complete job in a bit more than an hour. Cake walk
08-08-2003, 02:59 AM | #4 |
to add, May need to change out the pitman arm, the Hole diamention is smaller on a manual than on the PS one
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction). Progress on truck so far (follow link): http://67-72chevytrucks.com/vboard/s...ad.php?t=51051 and stage 2 http://67-72chevytrucks.com/vboard/s...ad.php?t=58132 ~ "Why couldn't you have just put the bunny back in the box?" ~ |
08-08-2003, 03:18 AM | #5 |
You will need a gearbox, hoses, pump, pump brackets, pitman arm & a integral power steering coupler. Watch out using 78 and newer pumps they went to using metric fittings at the hoses so don't mix a early pump with later gearbox or visa-versa.
GMCPaul |
08-08-2003, 06:52 AM | #6 |
ps
That's the best mod you'll ever do to a 4x4. They drive like a tank without it, and like a truck after.
08-08-2003, 11:04 AM | #7 |
cant go without the power steering
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
