Old 08-09-2014, 05:02 PM   #1
1966
should there be an o-ring on this (th350 detent)
After spending 2hrs removing all the caulking the PO covered the old detent cable with, I unbox my new ATP detent cable (#Y-103) and it seems to me like there should be an o-ring between these plastic ridges. Yes? Box didn't have one... Typing and attaching a photo via phone, hope this works...
1966 is offline   Reply With Quote
Old 08-09-2014, 05:27 PM   #2
siggyfreud
siggyfreud's Avatar
Re: should there be an o-ring on this (th350 detent)
I believe mine has an o-ring. I'll go check here in a bit.
siggyfreud is offline   Reply With Quote
Old 08-09-2014, 06:10 PM   #3
1966
Thanks siggy that'd be a huge help to me.
Just look at this SOB, so mad right now:
Attached:
Old 08-09-2014, 09:53 PM   #4
siggyfreud
siggyfreud's Avatar
Okay so I don't have a definitive answer for you, since I'm using a 700r4 now but, I believe what you need is a flat rubber washer that goes on the flat edge where the thing bolts into the transmission. That's what I have.
I would think an o-ring would still go in those grooves, but my detent/TV cable looks different, and doesn't have a long shaft with grooves like yours does.
Apologies for the delayed, and perhaps unhelpful response .
Old 08-09-2014, 09:54 PM   #5
1966
No worries! I really appreciate your efforts!
Old 08-09-2014, 09:55 PM   #6
siggyfreud
siggyfreud's Avatar
No problem. Re-posting as I just uploaded the photo.
Old 08-09-2014, 11:51 PM   #7
1320warrior
Yes there is supposed to be an o ring. I just dealt with this same issue on a friends 62 impala
1320warrior is offline   Reply With Quote
