08-10-2014, 08:57 PM | #1 |
gas filler neck
What is the best why to put the upper fill neck and neck gasket [seal] in? Put the gasket on the filler neck, then install or put the neck gasket on the then try to install the filler neck up through it. I know it installs from the inside. Both look like a pain. 53 3100
08-10-2014, 10:21 PM | #2 |
Re: gas filler neck
Just replaced the gasket and the hoses on my 55 2nd, and put the gasket in the hole in the cab with a little silicone spray lube. Then the filler tube slid into the gasket with no problemo. A little silicone lube on the hoses, and they slid into place.
'55 Chevy 1/2ton pickup w/ Pontiac 350 and Muncie M21 close ratio 4speed "Red Ryder" |
08-11-2014, 01:51 PM | #3 |
Re: gas filler neck
I guess Iam going to have to get some silicone spray and give it a try. thanks capnduane
