08-11-2014, 03:46 AM | #1 |
1960-1962 4x4 tank?
Does anyone make repop underbed fuel tanks for 4x4's? The tank in my truck isn't original and I'd like to find the right one... Any leads would be appreciated!
08-12-2014, 12:11 AM | #2 |
60-66 Nut
Re: 1960-1962 4x4 tank?
No one repops the fuel tank for the '60-'66 Suburbans and Panels. Since yours is a 4x4, the frame width should be the same as a '63-'72. In which case you could use the '69-'72 Blazer tank with a 0-30 ohm sender. You just won't be able to carry a spare tire underneath.
08-12-2014, 02:27 AM | #3 | |
08-12-2014, 02:31 AM | #4 |
I found a tank locally but I'm not sure if it's the right one. Does anyone have a 60-62 4x4 Panel/Suburban that still has the original tank? If so I could really use the measurements.
08-12-2014, 04:31 PM | #5 |
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
