Old 08-11-2014, 06:15 PM   #1
longhorn70gmc
longhorn70gmc's Avatar
73/75 and 78/79 doors Question
All,
We have four trucks worth of doors both factory and after market. What I want to know is even after measuring and getting different stats on the doors, what can acually be used. We want to put 78/79 doors on a 73 and 75 cabs and original front clips, will they fit? Most likely it will be a try it and see thing, but trying to work smart not hard concept. Thanks in advance!!!!! Tried FAQ section, nothing coming up.
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
longhorn70gmc is offline   Reply With Quote
Old 08-11-2014, 06:19 PM   #2
KrazyRay
KrazyRay's Avatar
Re: 73/75 and 78/79 doors Question
I have a 74 with 79 doors on it. They function well.
KrazyRay is offline   Reply With Quote
Old 08-11-2014, 07:00 PM   #3
Jonboy
Slots go on anything!
The external dimensions are the same, so they will bolt up. The shape of the interior sheetmetal is different, and the window regulators are different as well. Use the hardware and trim panels from the 78/79 doors and it will work fine.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 08-11-2014, 07:40 PM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
might be able to use some later stuff too
I'm using 89 burb (locking) vents,
door glass,(it's thinner too)
door panels,
window cranks,regulators
interior pull handles on 78 doors
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 08-11-2014, 08:13 PM   #5
bigblock73
yeller
bigblock73's Avatar
The breakdown is 73-76, 77-87(91)
Original 73-80 GM truck doors are also 1/4" wider across the body line than the 81 up doors, due to the front clip change...so if you put 81 up doors on a 73-80, there will be a slightly wider door/fender gap than what GM delivered off the line.
bigblock73 is offline   Reply With Quote
Old 08-12-2014, 03:57 PM   #6
longhorn70gmc
Smile Re: 73/75 and 78/79 doors Question
Thanks all, I appreciate the help and feedback on this. It will make things easier for us!!!!!
Billy
Hub Cap Freak!
Old 08-12-2014, 04:05 PM   #7
longhorn70gmc
This would make a great FAQ Reference for 73-81 GM Truck Doors!!!!
Billy
Hub Cap Freak!
