![]() Join Date: Sep 2002
Question on replacing oil pan on 87 V10
After looking over the 87 V10 I recently picked up, it appears that the oil pan may be leaking. I would like to drop the pan and replace both it and the gasket.
Question is can I drop the pan with the engine in the truck? Any info is appreciated. Thanks Scott
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
Re: Question on replacing oil pan on 87 V10
yes you can you you will need to remove the long bolts thru the motor mounts and raise up the engine a little bit that helps when dropping the pan.. also when you go back with the new gasket buy the good neoprene gasket by felpro it comes with four plastic studs that you can screw in each corner that holds up the gasket when you put the oilpan back on after you get the pan bolted up with some of the center bolts they will screw rite back out and you can put the four corner 5/16ths bolts back in hope this helps
4x4k30 if trouble was money i would have plenty |
Thanks very much for the info. Looked like it could be done but wanted to check.
Scott
Finally ready to do this job. Can anyone tell me for sure if the engine has to be lifted or if the pan will squeeze out without going through lifting the engine for clearance?
Thanks Scott
![]() Join Date: Oct 2011
I was able to do mine without lifting the engine.... Did have to remove the dust shield on the trans torque converter but that's it...
In my 74 all I had to do was drop the dust shield and it comes in and out easily.
If you have an automatic transmission you may have to move the lines a little bit. |
