Old 08-13-2014, 10:07 PM   #1
drillrod
72 K5 battery top posts or side posts
I asked this question a while back and was told that 72 chevy blazers came with side post terminals. Today I was told by a very well known chevy enthusiast that he assured me that they came with top posts. Does anyone know for sure which way they came so I can get the correct cables and battery? Thanks
drillrod is offline   Reply With Quote
Old 08-13-2014, 11:59 PM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: 72 K5 battery top posts or side posts
Side posts. Photo shows OEM cables in my 72 K1500 GMC pickup but K5s were similarly equipped. Member RogerKoop makes some very nice OEM-style repro battery cables - I have a set of his in my Blazer.
Old 08-14-2014, 04:15 PM   #3
JameslovesJammie
God Bless Mr. T
JameslovesJammie's Avatar
My '72 C/10 also has side post.
I do like running dual terminal 34/78 batteries like DeadheadNM has. It makes it easier to jump start Fords when I come across them on the side of the road.
Like a midget at a urinal...sometimes you must stay on your toes.
JameslovesJammie is offline   Reply With Quote
Old 08-16-2014, 11:45 AM   #4
fine 67
Junior Member
it was me that asked the battery question .if you in the factory parts book it listed side post only .the part number is still good because i ordered/gone both of them for my frame off return to oem . mark
fine 67 is offline   Reply With Quote
Old 08-16-2014, 06:40 PM   #5
Mike C
Mike C's Avatar
My '72 Jimmy was originally side posts. I am not a fan and it now has 2ga welding cable with copper lugs on the ends and marine terminals on a top post AGM battery. (Actually a pair of them with a factory auxiliary battery tray I added.)
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 08-16-2014, 09:26 PM   #6
drillrod
Thanks for the input guys
Old 08-16-2014, 09:54 PM   #7
franken
I'd ask who cares? Evolution has ridded us of side post batteries for a reason.
Side post batteries are crap because threads in lead is a brain damaged concept.
If I have a side terminal battery I'll put top post style adapters on it and never remove them.
I'd replace side terminal cables with good top post cables.
We aren't usually trying to win originality awards with these trucks.
Old 08-16-2014, 10:10 PM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
The OP simply wanted to know what the trucks were equipped with by GM. He didn't ask for your opinion regarding side vs. top posts. You may not care for originality in these trucks but many of "us" do.
Old 08-20-2014, 10:50 PM   #9
franken
Well, no one asked for your opinion either, but there it is.
Not sure who your misquoted us is, but bad design is bad design.
If you choose to use a bad design for the sake of originality, that's fine. Chances are you (and the mysterious us) will probably be replacing batteries before their time due to stripped threads in lead.
Old 08-23-2014, 06:59 AM   #10
rstrick
And just why would you be removing and reinstalling the battery connections so many times that you risk damage to the terminals? I've had this truck for over three years and only removed the connections once. Unless, perhaps, you just like to practice. The possibility is there but anyone who is on this board - that mysterious "us" you asked about - is probably competent enough to do things correctly.
rstrick is offline   Reply With Quote
Old 08-17-2014, 12:24 PM   #11
fine 67
Junior Member
if anybody wants the oem gm cable part numbers i have them .
Old 08-17-2014, 12:35 PM   #12
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Absolutely - please post when poss
Old 08-17-2014, 04:50 PM   #13
tjsblazer
tjsblazer's Avatar
^^ x2 please.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 08-17-2014, 08:30 PM   #14
drillrod
Thanks DeadheadNM
Old 08-18-2014, 10:16 AM   #15
briank
Did this change for 72? I have yet to look in my 72 service manual but my 70 manual shows a top post battery as well. Does not show it pictured in a blazer, just pictures of the batteries themselves.
briank is offline   Reply With Quote
Old 08-20-2014, 05:03 PM   #16
doo142
doo142's Avatar
My 70 is original and they are top, I've been thinking of starting a thread for differences in each year of production. The 69-70 are a bread of their own!!
doo142 is offline   Reply With Quote
Old 08-20-2014, 08:08 PM   #17
DeadheadNM
Carpe manana
DeadheadNM's Avatar
72 trucks have side posts for sure from GM (so does my 1999 suburban)
Old 08-21-2014, 12:43 AM   #18
GuyO
GuyO's Avatar
I dropped my long box end (1/2") on my top posts after reinstalling a charged battery in my Blazer. Guess what - "BOOM" as it arced between the posts. My ears rang for 3 days and I couldn't find my wrench for a week. The smoke set off the fire alarm too! It was nasty. Personally I am one for side terminals and didn't know my K5 was supposed to have them. Jumping tops is easier, but I can attest to the danger of them as well. Also, there is nothing wrong with opinions, they make us all think. My opinion. G.
GuyO is offline   Reply With Quote
Old 08-23-2014, 06:11 AM   #19
old man jimmy
since i ordered my 72 new.. I can tell you 100% for sure that they came with side post. And I prefer side post...Less corosion..and always stay tight. still using the original cables. Matter of fact, I've changed all my other old cars to side post also.. Only thing i've ever found a hassel with them is some times it's hard to get jumper cables on them.
old man jimmy is offline   Reply With Quote
