08-13-2014, 10:13 PM | #1 |
Frame Question????
I bought a truck as a project a while back. Getting ready to work on the frame and ran into an issue. The truck is titled as a 67. The frame is 5 lug, with leaf springs. Guessing it is a 71 or 72?? I was going to order a front end rebuild kit but 71 and 72 are different part numbers from 67-70. Is there any way to be sure what frame I have?? Thanks in advance, this site has been super helpful so far!!!!!
08-13-2014, 10:27 PM | #2 |
Re: Frame Question????
you need to locate the numbers on the frame, 1st is where the power steering would be on top of the rail and the second under the cab area on the side of the rail on the outside. You will have to look for numbers on the spindles to help decode the front end. Plus pictures help.
08-13-2014, 10:35 PM | #3 |
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
08-13-2014, 11:09 PM | #4 |
Should be on the top of the driver's side frame rail I believe between the power steering and upper control arm. I don't remember if the whole vin is on there but one of the 1st digits should be a 7 if it's a '67 frame. Sorry going off memory.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
08-14-2014, 09:46 AM | #5 |
Also most 67 frames don't have dimple to install power steering box. The frame will be straight in that area between the bolt holes, but remember some 68 frames will Also be like this....
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
08-14-2014, 10:18 AM | #6 |
Thanks guys. I will find the vin on the frame today after work and see what I have. It is power steering and power brake frame so Im thinkin 71 or 72. This is the first truck I have built. If it was a camaro I could use the roladex in my head to figure it out...Thanks again guys I am sure there will me more questions to come...Gonna post some pics soon of the build....
08-14-2014, 10:33 AM | #7 |
You have to remember, a popular upgrade for these trucks is to go five lug by swapping in a '71 or later rearend and front spindles. I would just buy for both, then return the ones you don't need. Most of the parts that differ are only $20 - $30 bucks, so it wouldn't be a big hit. It's alot harder to swap a frame than to swap rearends and front suspension. This is what I did on my '67 lwb. Total cost this way is $300ish for the major components.
If I have to be on 4 wheels, It has to be a classic Chevy 1967 c10 Longbed (Hawghauler/Icy weather transport) 2003 BMW K1200GT (Rain bike) 2007 Softail Deuce (Sun bike) 2009 Ultra Classic Electra Glide (Everything else bike) |
08-14-2014, 01:46 PM | #8 | |
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
08-14-2014, 05:30 PM | #9 |
It is a GMC and I also thought they were all leaf in the rear. Only numbers I can find on the frame are 231 on the front passenger side. Got more info. Truck was once a mud drag rig. Guy I bought it from said the frame was swapped before he bought it. He's in his early 30's and bought the truck when he was 14. Which parts of the rebuild kit are different??
08-14-2014, 05:30 PM | #10 |
Crap can't even see the numbers in the pic.
08-14-2014, 07:24 PM | #11 |
member #16
Here's where the no. is located. You should find a number then a letter and a sequential run of the s.n. first number is yr model the letter is the assembly plant. 1Zxxxxx would be a 71 yr model assembled at fremont ca.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
08-14-2014, 11:06 PM | #12 |
Thanks. I'll look again tomorrow. Frames been painted a few times. Might have to clean the paint off. Sure didn't see it earlier.
08-29-2014, 02:57 PM | #13 |
Here are the only numbers I can find on my frame. I did call CPP and found out the tie rods are different size so I'm gonna pull one off and hit the parts store. Did try to google the numbers I found on the frame but no luck. Do the numbers mean anything??
08-29-2014, 05:39 PM | #14 |
Those dont mean anything. Some think they may be part numbers of the frame rails. You need to find the numbers that John pointed out is his pic, Or if the frame is bare it is on the top of the driver side frame rail between the cab mounts too. It will be smaller and not as deep as those you pictured. Grab a wire brush and start searching.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
08-29-2014, 05:41 PM | #15 |
Post a couple pics if the whole frame too. I see a 73+ prop valve and brake lines on the front cross member.
08-29-2014, 05:42 PM | #16 |
I could never find mine, have to try again.
Someone above thought GMCs only had leaf springs. My Dad's 68 GMC had coils with an overloader half-leaf I believe. But it was coils and trailing arms for sure.
08-29-2014, 07:41 PM | #17 |
Those are the only numbers on this frame. I'll get pics tomorrow of the whole thing. Guys at CPP were helpful
08-29-2014, 09:16 PM | #18 |
The following is for 1/2 and 3/4 ton 2 wheel drive. GMC trucks came standard with leaf springs,, coils optional. Chevrolet was coils standard with leaf springs optional . |
08-29-2014, 10:23 PM | #19 |
Here's a pic of where it is on my '68
Right in front of the engine crossmember.
In the garage: The project - 1968 C10 Short box The hauler - 1994 K1500 Silverado Z71 - Sold 2015 Colorado Z71 |
