08-15-2014, 03:58 PM | #1 |
replacement sheet metal from lmc
So im wondering if anyone has used the sheet metal available from lmc specifically bed pieces.... end caps or tail light housing in case end caps isn't the right term any input would be appreciated as far as fitment and such
08-15-2014, 04:17 PM | #2 |
It's Better With Nitro
Re: replacement sheet metal from lmc
I pretty sure the aftermarket sheet metal (repair panels, fenders, etc.), are all stamped at the same factory. The ones that I have used, they are close, but expect to do a lot of massaging.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
08-16-2014, 12:46 AM | #3 | ||
But Found Her 25yrs Later!
The definition of shape between two cab corners I got were surely from different stamps. Quote:
08-15-2014, 04:18 PM | #4 |
I order all my sheet metal from Top Banana and have been satisfied with everything I've ordered. Most catalog companies use one of two or three sheet metal companies and its a crap shoot on what you'll get with fit and finish. Have heard a lot of good stuff about Goodmark lately too.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
08-15-2014, 10:09 PM | #5 |
Appreciate the input checked.out top banana and goodmark although at least on my phone i was only able to go back till 1975 with goodmark the products at top banana seemed like a good deal a lot less costly than LMC for sure so at the price I'll see what happens...updates when part arrives
08-16-2014, 01:49 AM | #6 |
dont buy goodmark doors they look great but dont fit worth $hit gave up trying to line mine up and have decided to leave them on with the bad fit
