08-16-2014, 09:13 PM | #1 |
how much will it really pull
how much will a 79 k20 with a 4 speed and 4.10 gears and a 350 really pull. i know what they are rated for but I've seen people pull some pretty big stuff. would it pull an 18 foot car trailer with a car on it
08-16-2014, 09:22 PM | #2 |
Re: how much will it really pull
That combo will pull an 18 foot car trailer loaded with no problem. I had a 292 in my truck and towed everything I could fit on trailer. easily will tow 8k.
1972 3/4 ton 402/400 1971 k20 lwb 8.1.4l80.np205 w/37" tires and 6"lift |
08-16-2014, 09:37 PM | #3 |
Yea it'll tow it bla bla bla. Yea mine pulled such and such's big 1 ton yadaa yadaa. Pulling is the easy part... Just make sure you can stop and give yourself plenty of room. I know, kinda sounding like an ass here and sorry if i offend you. Just better safe than sorry... Running halfway over the ricer in front of you with a 1 ton ford on a car hauler in your truck is some scary $hit.
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
08-16-2014, 10:21 PM | #4 | |
'86 Chevy K10 SWB Custom Deluxe 4x4 '94 Chevy Corvette '07 Ford Mustang '08 Lexus LS 460 |
08-16-2014, 09:38 PM | #5 |
no offended at all. i guess you can really pull anything as long as you can stop
08-17-2014, 03:10 AM | #6 |
It just depends how much the car and the trailer weight if you should pull it or not.As far as being over loaded its a nice fine if you get caught.
08-17-2014, 11:35 AM | #7 |
A car and trailer is a pretty light duty load. Stations wagons used to pull that easy enough. A K20 with bigger brakes will have no problem at all.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
08-17-2014, 12:48 PM | #8 |
The bottom line is there are a lot of different variables including...
1) Ratings of tow vehicle 2) Hitch type and rating (don't forget goose neck) 3) Trailer type (single/tandem axle) 4) Tongue weight 5) Trailer brakes 6) Weight of load 7) Weather, terrain and altitude (higher the less engine power you have) Every situation is different. Personally, if it where me I would want a tandem axle trailer with brakes which it sounds like you have covered.
08-17-2014, 01:30 PM | #9 | |
If the truck cannot launch at GCVW then the rating is knocked down until that configuration passes the specific test. That weeds out a lot of combinations that would have been rated higher. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
08-18-2014, 11:58 AM | #10 |
X2.... STOPPING is the issue in my book !!!!!!!!!
08-17-2014, 01:25 PM | #11 |
One thing Not mentioned is the drivers experience. I used to drive semi truck. Back in my late thirties & early forties I was a heavy hauler. the truck was engineered for a 80,000 pound pay load. Yet I commonly hauled loads grossing 180,000. The truck could pll it Ok. Going down steep grades and stopping was the tricky part. My expierence allowed me to do the job without incident. It was legal because we purchased overweight permits. Even today I pull trailers behind my 66GMC 1/2 ton. It has a granny four speed and will pull ok. The drum brakes and single master cyl and the fact that my trailer brakes are very poor makes it unsafe for the novice. I never have problems because I Know How. there isn't a weight limit on 1/2 or 3/4 ton trucks in Arkansas. As long as you don't exceed the weight limit rating on the sidewall of your tires.
08-17-2014, 01:29 PM | #12 | |
K
08-19-2014, 08:26 AM | #13 |
when i was dumb and thought i could do anything i would pull 20k plus with my truck starting is ez mantining ez it was the stoping. now years later and a class a cdl i look back and say what a fing dumbass i was. what if some kid ran out? there was no stoping that truck and trailer at all. my c20 with 4 sp llow will pull a bobcat trailer and cat no problem. little more and she is not all that happy. get a good contorler and make sure the brakes are good on the trailer. also. balence the load all on the tail no good all on the noise no good. with mine i found just a tuch forward on the trailer and the ride was good the brakes where good and no wondering down the road
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
08-19-2014, 08:36 AM | #14 | |
Desert |
