Old 08-17-2014, 01:00 PM   #1
Chevysixtysix
4 speed swap
I have a 66 c10 1/2 ton long bed truck. It's an og 3 on the tree inline 6. I want to put in a Muncie sm465 4 speed I bought n want to know what size clutch kit do I buy. I also noticed my drive shaft connection is different looks like the one I have in now slides in the tranny n the one u bought takes a yoke. Any easy swap from a different year..
Chevysixtysix is offline   Reply With Quote
Old 08-17-2014, 02:30 PM   #2
AJNapierski
AJNapierski's Avatar
Re: 4 speed swap
Have you ever driven a granny gear 4 speed? If you converted that thing to the floor you would have the same exact thing without the granny gear (which is useless unless you need to hill start a heavy trailer or lug down a grade, good for 4X4's though). Just type in "chevy 3 on the tree floor conversion" on your search engine the kit should be cheap and take a weekend to put in.
AJ
AJNapierski is offline   Reply With Quote
Old 08-17-2014, 02:37 PM   #3
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: 4 speed swap
^Yeah, unless you plan on pulling stumps.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 08-17-2014, 03:29 PM   #4
66Submarine
66Submarine's Avatar
Re: 4 speed swap
You need the HD 2 piece driveshaft with the slip yoke in the middle if you use the 4 speed. You also really should have the 4 speed removable transmission tunnel/hump, but I have seen someone that managed to wedge one in a low tunnel truck before (IIRC it had a homemade removable cover).
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 08-17-2014, 03:33 PM   #5
66Submarine
Re: 4 speed swap
BTW, as previously mentioned, the 4 speed is driven like a 3 speed on the road; you shift 2-3-4. 2nd (used as 1st) is deeper than 1st in the three speed (wider ratios), and the whole thing shifts a lot slower. 2nd is synchronized, though.
Old 08-17-2014, 08:46 PM   #6
Chevysixtysix
Re: 4 speed swap
So the 4 doesn't sound like the way to go. What do you guys recommend maybe a 5 speed out of a s10 or something. My plan is to have a floor shifter so I can delete the column shifter
Old 08-17-2014, 08:53 PM   #7
Re: 4 speed swap
Just get a Hurst 3 speed shifter and then you don't have to do any tranny swap. Makes a world of difference on how the truck shifts.
I used this one in my old 70 C10 and loved it. Very precise.
Not sure what brand is in my 64 at the moment (cheapie one), but I will be swapping it out in near future.
http://www.summitracing.com/parts/huu-5010016/overview/
Here are some others that should do well also.
http://www.summitracing.com/search/p...20for%20Trucks
Old 08-17-2014, 08:56 PM   #8
LostMy65
LostMy65's Avatar
Re: 4 speed swap
I would do what AJ and Palf70 suggests;
Get a floor shifter for the tranny you already have.
Old 08-17-2014, 09:01 PM   #9
66Submarine
Re: 4 speed swap
Yeah.
The column shift works just fine when it's not worn out IME/IMO, though (I converted my 3 speed truck back to the column). It's also kind of nice when you have three people in the truck.
Old 08-17-2014, 10:53 PM   #10
C10 - C90 Bill
C10 - C90 Bill's Avatar
Re: 4 speed swap
Well, I always use Granny Gear 1st when I drive them, even empty, lol, but I love it for off-road, pulling a Trailer or carrying a Heavy Load.
But just for every day light duty driving, the 3-Speed will do fine.
The biggest problem with converting to a SM 420 or 465 in my opinion, is the Floor Hump as mentioned above. That has actually stopped me from converting a few.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
