08-17-2014, 02:25 PM | #1 |
Quick One....Oil pressure gauge fitting
'72 C20, does anyone know what the size is on the fitting on the back of the factory wet oil pressure gauge? Ive got a 4 AN braided line coming from the motor, but need an adapter for the back of the factory gauge. Thanks!!
08-17-2014, 02:28 PM | #2 | |
Cluster King
Re: Quick One....Oil pressure gauge fitting
Hope this helps
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
08-17-2014, 02:54 PM | #3 |
mine is actually a male fitting that will require a female adapter for the braided line. there is a small, copper retaining nut that keeps the gauge in place in the housing. I need to know the size of that retaining nut as the adapter will be the same size. I can probably back the nut off and take it to the hardware store tomorrow, I was just hoping someone might know off the top of their head. Thanks for the help.
08-17-2014, 03:07 PM | #4 | |
Cluster King
The inside is where the factory line with the compression fitting /farrel nut would thread into. If you found a fitting that would thread on the outside with the nut, there would be nothing to stop oil from leaking. I hope this helps and I am following what you are asking for.
08-17-2014, 03:27 PM | #5 |
ahhhhh....that is hugely helpful....thank you very much!
08-17-2014, 03:32 PM | #6 |
just ran down to the garage, and now I am following completely, and yes you are correct....so you think that inside diameter is 1/8 NPT male to a 4 AN male fitting for the line?
http://www.summitracing.com/parts/aer-fbm2512 |
08-17-2014, 04:02 PM | #7 |
One of our site vendors Leon (LockDoc) makes these copper oil pressure lines. http://67-72chevytrucks.com/vboard/s...d.php?t=613373
The end with the compression nut threads into the factory gauge. Hope this helps.
1971 Bone Stock C10 project "Jake" 1997 Sierra SLT factory short bed "Silver Bullet" |
08-17-2014, 04:35 PM | #8 |
I looked for this same fitting and never could find it. I don't think it is pipe thread. I wanted to run braided line but just went with the copper line. I hope you can figure this out.
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
08-17-2014, 05:45 PM | #9 |
My gauge has a 5/16-24 internal thread and 7/16-20 outside thread. just checked my old gauge..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother |
08-17-2014, 09:54 PM | #10 |
The Older Generation
Here is a picture of the fitting that screws into the gauge. It isn't 1/8 inch pipe tread. I don't know of any other fitting that will fit it.... LockDoc
08-18-2014, 10:27 AM | #11 |
Here is the only way it could be done as far as I can see. If a person would order this fitting: http://www.andysautosport.com/produc..._17982nos.html And use this adapter that I made up (the small end fits the back of the gauge and the 1/8” pipe threads on the big end fit the 4-AN adapter that Andy’s Auto Sport sells, then your 4-AN oil line would screw into that. Maybe a person could find a cheaper Female 1/8” pipe to Female 4-AN fitting that didn’t swivel, I don’t know. LockDoc
08-18-2014, 10:38 AM | #12 |
I have some of the fittings that LockDoc posted. I bought them a while back from someone on this site.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
