Old 08-19-2014, 02:37 PM   #1
sixysixss
Which Rubber Products For Vent Window Rebuild?
Getting ready to redo my vent windows. Before I buy the parts, I'm looking for opinions on where to buy the rubber. For those that have done it, which rubber or kits offer good longevity and quality -- which rubber products fit best and last longest? Let's hear some testimonials. Thanks.
sixysixss is offline   Reply With Quote
Old 08-19-2014, 03:01 PM   #2
cg285
Re: Which Rubber Products For Vent Window Rebuild?
i got some from lmc and the rubber cracked before they got reinstalled. i have a 64 that is (was) ALL original and the vent rubber still looks like new. i have to assume that all the suppliers get their products from the same port in taiwan or china - i could be wrong tho'
cg285 is offline   Reply With Quote
Old 08-19-2014, 03:18 PM   #3
pimpston65
pimpston65's Avatar
i got mine from a pick, they were by Steele. i think they are great, but pricy good thing i paid half from a builder selling his truck in pieces
pimpston65 is offline   Reply With Quote
Old 08-19-2014, 04:19 PM   #4
sixysixss
Looks like the Steele seals are almost $100!!
Another question -- what did everyone use to put the glass back in the frame, glass setting tape or glazing urethane?
Thanks.
Old 08-19-2014, 08:23 PM   #5
theastronaut
theastronaut's Avatar
Precision makes great seals.
Use glass setting tape, make sure you get the right thickness or the glass will be too loose, or too tight to install in the frame. It's better to go slightly loose if you can't get the correct tape and use a couple dabs of urethane on the ends. If you only use urethane then you'll never get the glass out of the frame if one ever breaks.
theastronaut is offline   Reply With Quote
Old 08-19-2014, 10:00 PM   #6
pimpston65
pimpston65's Avatar
i use pieces of closing panel rubber to mock it up and is just like the rubber that appears original and is exact same thinkness bad thing i dont have enough:-(
Old 08-20-2014, 08:20 AM   #7
1963c-10
1963c-10's Avatar
x2 on precision
1964 Short bed trailer
Old 08-20-2014, 11:06 AM   #8
sixysixss
Where can I buy Precision seals? Thanks.
Old 08-20-2014, 11:09 AM   #9
sixysixss
Found it! Precision Restoration Parts. thanks.
Old 08-20-2014, 12:07 PM   #10
kcsa75
kcsa75's Avatar
Originally Posted by 1963c-10 View Post
x2 on precision
x3
Look up GMC Pauls or Classic Heartbeat. Both vendors sell Precision and support this forum.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
