08-20-2014, 05:23 PM | #1 |
1967 power steering gear box
I am having a HARD time finding a 67 power steering gear box, mine is leaking like crazy. Everybody I call says, "We have a 66 and a 68 but no 67". Any ideas? There is a place that offered to rebuild it for around $260, but was hoping to find one already rebuilt for less than that.
08-20-2014, 05:48 PM | #2 |
Re: 1967 power steering gear box
1967 (or earlier) never came with an integral power steering gear. They had ram assisted power steering, completely different animal. Just buy a power steering gear box from '68 or newer, even 73+ trucks up to 1980 ? (Sometime around there they switched to metric O ring fittings).
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
08-20-2014, 09:17 PM | #3 |
Project Junkie! Fishing Poor!!
68 or earlier used ram assist power steering. The 67 chassis is not dimpled for the integral gear that the 69 up used. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
08-20-2014, 10:17 PM | #4 | |
Takes less than an hour. Done use any 68 and up PS Box
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
08-20-2014, 10:19 PM | #5 |
Forgot the last pic
08-20-2014, 10:33 PM | #6 |
Might want to post pics of the current setup so the wizards can see what you have.
You may have a conversion that you can get a rebuilt box for easily, or er, not. |
08-21-2014, 09:32 AM | #7 |
08-21-2014, 03:16 PM | #8 | |
If 67 see frame mod above first If 68-72, acquire a Power steering box New rag joint Power steering brackets (2 parts) Power steering pump and pulley Crank shaft pulley if yours is not equipped Hoses: 1 pressure, 1 return Be aware that you get a matched set of pump / gear / hoses there are flare style connections and there are o-ring style connections All work the same but you can't mix them up without having adapters $ Do some searches on the site, someone will have a kit for sale somewhere.
08-20-2014, 10:57 PM | #9 |
Yea, we might have jumped the gun, without knowing the whole story.
08-21-2014, 09:22 PM | #10 |
Get a box for a '78 C10. Correct fittings and only 3 1/2 turns lock to lock :-)
08-22-2014, 12:09 AM | #11 |
Good to know!!
08-22-2014, 11:39 AM | #12 |
Will the 67/68 pitman arm work with this 78 box?
"The Mustang’s front end is problematic, get yourself a Firebird. "- Red Forman |
01-29-2015, 01:25 PM | #13 |
How does this ratio feel? Why is it better?
Figure out what you want--then figure out what you are willing to give up to get it. |
01-29-2015, 01:32 PM | #14 |
08-22-2014, 09:46 AM | #15 |
IS THE K-10 FRAME DIFFERENT FROM THE C-10 FRAME ? Because my k-10 67 frame dont have no dimple and the power steering gear box bolts right up, maybe im going crazy???
08-22-2014, 06:57 PM | #16 |
08-23-2014, 09:50 PM | #17 | |
Are you sure your frame is a 67? If so do you know the build month/year of your truck?
10-21-2017, 11:47 PM | #18 | |
I finally spread some JB Weld on the crack on my manual steering sector and went back to the old Armstrong system. Still steered funky, since I had cut up the original drag link. The K trucks had a steering sector that moves front to back, the 2wd trucks went left/right. Big time problems. Look for ram assist power steering on corvette forums. That's compatible but way expensive. Or do curls and build up your forearms. Wow. I just answered a ''ghost post''. Never met Fitz either, although he was in Tucson when he was active on this board.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 10-21-2017 at 11:56 PM. Reason: ghost post |
08-22-2014, 12:46 PM | #19 |
I saw this at Rock Auto, under steering gear for a 1968 1/2 ton Chevy truck. When you click the link, it says they are rebuilt in the USA. I don't have any experience with them, but the price does not look bad.
LARES Part # 1075 Remanufactured; Power Gear w/ 3 - 3-1/4 turns box and core costs $136.79 $86.79 $50.00 $136.79
1970 2WD K5 1968 Camaro Conv 1967 Chevy SWB 1964 Malibu SS 1957 Corvette Pics www.picturetrail.com/wesmigletz |
08-22-2014, 02:13 PM | #20 |
Yup . Pitman arm is the same.
1967custom |
08-22-2014, 02:36 PM | #21 |
Thanks!
08-23-2014, 10:00 PM | #22 |
1978 C10 gear on RockAuto ATSCO Part # 7512 $109 with $19 core
09-10-2014, 02:56 PM | #23 |
Does anyone know if the manual and power steering rag joints are the same?
Thank-Mika |
09-10-2014, 03:13 PM | #24 | ||||
01-29-2015, 02:15 PM | #25 |
No, they are not. My 67 frame is dimpled for the steering box as can be clearly seen in the photo's below. Before you say the frame can't be a 67 with a dimple, the partial vin stamped on the upper side of the frame rail on the drivers side, just behind the steering gear matches the full VIN on the B pillar which decodes as a 1967 C10 six cylinder 1/2 ton built in the Atlanta assembly plant. My truck was #1294 of the first production run which means it was likely shipped in October or November of 1967.
