c-notch install help 68 chev truck
Hi everybody i bought a c-notch kit from classic performance parts
i was wondering if anybody had any step by step procedure to install the c-notch kit on my truck any help would be great pictures anything thanks eveybody |
Re: c-notch install help 68 chev truck
Uh. C notch isn't really something you wanna try n do if you don't know what you're doing, prolly better off finding a shop to do it, It'll cost more but it'll be done right.
Jack Personal Fleet: Family Fleet: 1955.5 Panel 1959 Apache 1968 ShortWide 1969 ShortStep |
Here you go. http://67-72chevytrucks.com/vboard/s...d.php?t=196013
Good luck with your install. Just make sure you don't remove too much frame where you could possibly create a large gap that will need welded up. You want every bit of the C- notch touching the frame notch...just take your time.
Scott |
If you have the budget for a Porterbuilt 2 piece C-notch it really is the way to go. It is so easy to install once you get pass all the rivets that need removed first. The metal is 2x thicker than all the one piece c-notches.
Scott |
#5 | |
![]() Join Date: Apr 2012
To go back to the original issue though: Because I'm a moron ![]()
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
![]() Join Date: Jun 2013
TRACK70 BUILD -> http://67-72chevytrucks.com/vboard/s...d.php?t=589761 King's Speed Shop |
I did my own. I recommend using an air chisel to knock out all the rivets. That was the worst part of it.
Thanks, Casey ![]() The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045 The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699 |
#9 | |
This is one of those things that you really should not try if you do not know exactly how to do it and have the experience to do it right. A frame is a bit tough to fix once it's botched and your truck won't be worth much until it's done correctly. |
![]() Join Date: Jun 2014
This info might help you. Gives you an idea of what your getting in to.
I think anyone can do the job if they take their time. http://www.powernationtv.com/episode...6/in-the-weeds http://www.powerblocktv.com/episode/...r#.U_avVUgab-g |
thanks everybody for the responses i got the job done looks good now i just need to install
the deluxe trac bar and i am good thanks again i appreciate it |
Good deal, let's see some pictures now
Scott |
