Old 08-22-2014, 06:34 AM   #1
flykelley
72 rear axle ratio question
Hi Guys
My truck has a 72 frame and components, took the rear axle cover off to find the gear ratio. It appears to be a 4:11. This is a part number off the ring and pinion. part number is #381778 11:4 GM Seems that a 1/2 ton two wheel drive long box would come with a 3:73 rear end.
Mike
flykelley is offline   Reply With Quote
Old 08-22-2014, 10:16 AM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: 72 rear axle ratio question
Different gear ratios could be ordered back in the day, not to mention changed by previous owners. Best way to know for sure, with the cover off, is to count the teeth. Divide the teeth on the ring gear by the teeth on the pinion gear to get the exact ratio.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 08-22-2014, 11:36 AM   #3
mitchell72
mitchell72's Avatar
You could jack it up, spin the drive shaft 1 revolution and see how much the wheels spin.
mitchell72 is offline   Reply With Quote
Old 08-22-2014, 05:19 PM   #4
67c10rustbuket
67c10rustbuket's Avatar
Originally Posted by flykelley View Post
Hi Guys
.... This is a part number off the ring and pinion. part number is #381778 11:4 GM
Mike
If you look a little closer I bet it says 381778 11:41GM on the ring gear. This means 11 pinion gear teeth, 41 ring gear teeth. 41/11= 3.73. The original gears had these part number/ratio stamping.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 08-23-2014, 08:02 AM   #5
flykelley
Thanks Dan, I thought a 4:11 was a bit much for a 1/2 ton truck. Ill have my brother check it out.
Mike
