08-25-2014, 11:47 AM | #1 |
Can this fitting be removed??
I am running AN lines for my trans cooler to the radiator and I am trying to find out if the fittings that are on my radiator can be removed. By the looks of it I should be able unscrew the fitting with a 1 1/4" socket but I don't want to screw up the radiator. Has anyone else done this?
1969 Chevy K20 Longbed |
08-25-2014, 12:51 PM | #2 |
Re: Can this fitting be removed??
NO!
That is the transmission cooler. You have to have the tank off to remove that.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
08-25-2014, 01:14 PM | #3 |
you should b able to find an fittings that screw into that fitting to use your an type lines
08-25-2014, 02:22 PM | #4 | |||
"I ain't nobody, dork."
There are fittings available that adapt the -AN lines to standard flare fittings. Gary
08-25-2014, 01:55 PM | #5 |
While in theory you might be able to desolder them, don't. There are plenty of pipe to AN adapters out there. Probably as cheap as the fitting you'd need to install in the trans cooler if you even could.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
08-25-2014, 02:32 PM | #6 |
Thanks for the help. I didn't think that fitting was meant to come off and glad I didn't try!
08-25-2014, 03:31 PM | #7 |
I took this route. I bought a aluminum transcooler and mouted it to the frame and ran AN lines to it from the TH400. Plugged the ones in the radiator.
I am almost done with the truck now, it was nice having these pics before the cab was on the frame to share.
Thanks, Casey 71 Chevy C-10 SWB 350/400 PS, PB The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045 The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699 |
