08-25-2014, 02:39 PM | #1 |
Yet another little issue/question...
Hey again all,
I've been noticing another issue with my truck that's been showing up lately, I can't get an accurate fuel level reading, it'll go from full, to empty, to a quarter, to 3/4 then back to full in under a minute, and it repeats this cycle in random fashion every 10 minutes or so, is it just the fuel sloshing around in the tank, or do I have an issue?
1981 Sierra Classic 1500, 305 4BBL, Ltd. Slip Rear End |
08-25-2014, 04:11 PM | #2 |
Re: Yet another little issue/question...
Sounds like a shaky ground wire.
08-25-2014, 06:36 PM | #3 |
I agree with Gibson, it sounds like a loose wire somewhere. Your ground reference is a taco shaped metal plate with 6 tabs on it for various systems to ground to. It's mounted to the left of your E-brake pedal on the sheet metal. See if this is loose or rusting. You can also take out your instrument cluster and check the pins in the back of the cluster for corrosion or damage. But my money is on the ground reference.
Robert 1975 C10 - Huckleberry 2007 Jeep JK - John Wayne Jeep Smittybilt front/rear bumper, 10K winch Pacific Grove, CA |
08-26-2014, 08:13 AM | #4 |
If you don't find anything out of order on the ground reference under the dash, check the ground that comes off the sending unit back on the tank. Make sure it is really clean on both ends.
08-26-2014, 08:45 AM | #5 |
Seems that if it were the ground wire the gauge should be spiking to full+. I would lean toward the gauge itself. Fill you tank up and see how the gauge behaves.
2017 Silverado LTZ 6.2 1984 Scottsdale K10 - 468 700r 4x4 lwb 1978 GMC Sierra Grande K15 350 Soond to be 406 th350 4x4 swb 1968 GMC 20 305 V6 good ole wood hauler. Good Fences make good neighbors |
